I'd like to clear recent inputs in terminal not cls or clear but when you press up or down. How do I clear this list so that when I rename sudo to nodood or something you cannot press up to view the new sudo perhaps my script will read input.
EDIT: Note pressing Ctrl + R in terminal will let you search history like history | grep searchQueryString Another useful tip is sudo !! which re-executes last command with sudo prefixed
Punkroku
To clear your history use
history -c
Rinzwind
  • 309,379
Deleting history
  • If you only want to delete a single command (eg: you have erroneous typed your password) type
     history -d <line number>
  • In case you want to delete the entire history enter
     history -c; history -w
  • History files can be found in your home directory. For bash this will be .bash_history and the temp files .bash_history-xxxxxx.tmp. Hence deleting these files would be another option.
To find out more about history's hidden features take a look at the gnome bash manual.
abu_bua
  • 11,313
