I have installed Ubuntu inside VirtualBox and generally I can apt-get install anything but when I run
sudo apt-get install make
I get this response:
Media change: please insert the disk labelled
'Ubuntu 18.04.1 LTS _Bionic Beaver_ - Release amd64 (20180725)'
in the drive '/media/cdrom/' and press [enter]
I cannot do this as I'm in a VM and don't have a cdrom drive. I have successfully installed lots of packages using apt-get and I assume it gets them from the image I installed Ubuntu in the VM or online, so why does this problem occur for make?
Many thanks for any wisdom.
Zanna
  • 72,312
Ben
You should check your /etc/apt/sources.list – maybe the disk is still listed as a repository there.
karlsebal
  • 339
