I just created a virtual machine using ubuntu 18.04 on a kubuntu host machine. I tried to use the bidirectional shared clipboard option after installing guest additions on the guest machine. On the host machine I can't use sudo commands, which is the actual reason for me to use a virtual machine.
I already tried the solutions suggested in the first 3 answers of this post VirtualBox 4.12 Shared clipboard not working in Ubuntu14.04 except that i changed the commands in the third answer for the commands suggested in the comments, because someone said that the commands in the answer killed his ubuntu installation. None of the solutions worked.
Does anyone have any other solution?
The output of vboxmanage list extpacks on host:
Extension Packs: 1
Pack no. 0:
VNC Version: 5.1.38
Revision: 122592
Edition:
Description: VNC plugin module
VRDE Module: VBoxVNC
Usable: true
Why unusable:
Output of VBoxClient -V on guest machine:
5.1.38r122592
