I am trying to install pandoc 2.3.1 in my Ubuntu 18.04.1 LTS.
First, I remove any old pandoc version (in my case is pandoc 1.19.2.1)
manolo@manolo:~$ sudo apt-get remove pandoc
Reading package lists... Done
Building dependency tree
Package 'pandoc' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
manolo@manolo:~$ sudo apt-get remove --auto-remove pandoc
manolo@manolo:~$ sudo apt-get purge pandoc
Then, I run the following command to check the pandoc version that should have given me a blank result because pandoc is not installed. Although, I get the following result:
manolo@manolo:~$ pandoc -v
pandoc 1.19.2.1
Compiled with pandoc-types 1.17.0.4, texmath 0.9, skylighting 0.1.1.4
Default user data directory: /home/atai/.pandoc
Copyright (C) 2006-2016 John MacFarlane
Web: http://pandoc.org
This is free software; see the source for copying conditions.
There is no warranty, not even for merchantability or fitness
for a particular purpose.
Then, I try installing the new latest version of pandoc:
manolo@manolo:~$ sudo dpkg -i /home/atai/Desktop/pandoc-2.3.1-1-amd64.deb
Selecting previously unselected package pandoc.
(Reading database ... 263668 files and directories currently installed.)
Preparing to unpack .../pandoc-2.3.1-1-amd64.deb ...
Unpacking pandoc (2.3.1-1) ...
Setting up pandoc (2.3.1-1) ...
Processing triggers for man-db (2.8.3-2) ...
Although, when I check the pandoc version I still have the 1.19.2.1 installed:
pandoc 1.19.2.1
My guess is something regarding the path where pandoc is being installed.
manolo@manolo:~$ whereis pandoc
pandoc: /usr/bin/pandoc /home/atai/anaconda3/bin/pandoc /usr/share/man/man1/pandoc.1.gz
manolo@manolo:~$ type pandoc
pandoc is hashed (/home/atai/anaconda3/bin/pandoc)
