I am not a very experienced user, specially regarding system's technicalities such as this one. All I know is that when I first installed Ubuntu, I used the command df -h to check my disk space. It usually went like this
user@laptop:/home$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 2.9G 0 2.9G 0% /dev
tmpfs 585M 1.8M 583M 1% /run
/dev/sda2 457G 104G 331G 24% /
tmpfs 2.9G 29M 2.9G 1% /dev/shm
For the last couple of months, however, the results have been as follows:
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 2.9G 0 2.9G 0% /sys/fs/cgroup
/dev/loop0 141M 141M 0 100% /snap/gnome-3-26-1604/70
/dev/loop1 17M 17M 0 100% /snap/communitheme/1273
/dev/loop2 13M 13M 0 100% /snap/gnome-characters/117
/dev/loop3 3.8M 3.8M 0 100% /snap/gnome-system-monitor/57
/dev/loop4 3.8M 3.8M 0 100% /snap/gnome-system-monitor/54
/dev/loop6 2.3M 2.3M 0 100% /snap/gnome-calculator/222
/dev/loop8 141M 141M 0 100% /snap/gnome-3-26-1604/62
/dev/loop9 2.4M 2.4M 0 100% /snap/gnome-calculator/199
/dev/loop10 140M 140M 0 100% /snap/gnome-3-26-1604/64
/dev/loop12 227M 227M 0 100% /snap/pycharm-community/79
/dev/loop13 227M 227M 0 100% /snap/pycharm-community/83
/dev/loop14 3.8M 3.8M 0 100% /snap/gnome-system-monitor/51
/dev/loop15 43M 43M 0 100% /snap/gtk-common-themes/701
/dev/loop16 227M 227M 0 100% /snap/pycharm-community/85
/dev/loop17 88M 88M 0 100% /snap/core/5328
/dev/loop21 13M 13M 0 100% /snap/gnome-characters/103
/dev/loop18 88M 88M 0 100% /snap/core/5548
/dev/loop5 13M 13M 0 100% /snap/gnome-characters/124
/dev/loop20 15M 15M 0 100% /snap/gnome-logs/43
/dev/loop23 15M 15M 0 100% /snap/gnome-logs/45
/dev/loop22 2.3M 2.3M 0 100% /snap/gnome-calculator/238
/dev/loop24 35M 35M 0 100% /snap/gtk-common-themes/319
/dev/loop7 17M 17M 0 100% /snap/communitheme/1226
/dev/loop11 15M 15M 0 100% /snap/gnome-logs/40
/dev/loop19 17M 17M 0 100% /snap/communitheme/1201
/dev/loop25 87M 87M 0 100% /snap/core/5145
/dev/sda1 511M 6.1M 505M 2% /boot/efi
tmpfs 585M 88K 584M 1% /run/user/1000
As you can see, not only do I have 5 temporal filesystems, but also a ridiculous amount of /dev/loop entries. I have tried to look for a solution on the internet from time to time. The problem is, I dont even know what is it that I am looking for. The closest I got was to some post talking about inodes, and after barely getting a grasp of what an inode is, I couldn't get anywhere near finding someone undergoing the same situation.
To be honest, I don't know/think this is a problem. But I certainly do not like it. I would like to know what are these things, whats their relationship with the inodes (if I run df -i -h I get a similar result, from what I guess are the corresponding inodes to these mounts), what is the reason for their unusual multiplicity, should I get rid of most of them and, if so, how to do it.
Thanks in advance :D!
