I was running Ubuntu 16.04 in dual boot with Windows XP. I had it set up using a USB HDD so that at startup I was asked which OS I would use.
When Ubuntu 18.04.1 LTS was released back in Aug. I upgraded.
Tried to resurrect a sad USB stick using the Disks facility on ubuntu & accidentally erased a partition on the Ext HDD. Now without access to ext HDD, I cannot boot either OS, also no longer have access to windows or the files stored on USB HDD.
Have installed ubuntu on the computer HDD just to try to get some help. Have tried recovery software e.g. Trinity Rescue Kit, Testdisk. No, go! Can anyone please help me get my system back to the way it was and especially get access to my files again?
Hi David, thanks for the info so far.
It's getting way too complex and as a newb I'm way confused now.
Would a simpler solution be for me to reinstall windows and Ubuntu using wubi or whatever? then just recover my data with a forensic program. Or can I recover my data first then re-install all.
My problem is that when I boot up with the ext HDD connected I get "No such partition. Grub rescue" but cannot get to boot menu or BIOS unless I disconnect Ext HDD.
I then reconnect Ext HDD then cannot get to chroot to try pointing Boot repair at /sdc??
