After running into this bug: https://gitlab.gnome.org/GNOME/gnome-control-center/issues/236
I can't get my locale fixed. It is impossible to fix it with gnome-control-center, and "export LANGUAGE=gd:en_GB:en" will fix it in the current terminal only.
I have read https://help.ubuntu.com/community/EnvironmentVariables#Persistent_environment_variables
Also,
$ cat /etc/default/locale
LANGUAGE="gd:de_DE:en_GB:en"
LC_NUMERIC="gd_GB.UTF-8"
LC_TIME="gd_GB.UTF-8"
LC_MONETARY="gd_GB.UTF-8"
LC_PAPER="gd_GB.UTF-8"
LC_IDENTIFICATION="gd_GB.UTF-8"
LC_NAME="gd_GB.UTF-8"
LC_ADDRESS="gd_GB.UTF-8"
LC_TELEPHONE="gd_GB.UTF-8"
LC_MEASUREMENT="gd_GB.UTF-8"
LANG="gd_GB.UTF-8"
but when I log in again and start a terminal, de_DE is back like a bad penny.
I have edited /etc/common/locale as suggested, and this file is now clean, but the locale setting regressed. Regerating the locales has no effect, because the locales athemselves are not broken. Programs are still using German, and it's listed in the terminal. A reboot after applying the changes has no effect.
LANG="gd_GB.UTF-8"
$ locale
LANG=gd_GB.UTF-8
LANGUAGE=gd:de_DE:en_GB:en
<snip>
$ sudo locale-gen "en_US.UTF-8"
Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
$ sudo dpkg-reconfigure locales
  en_AG.UTF-8... done
<snip>
  en_ZW.UTF-8... done
  gd_GB.UTF-8... done
$ locale
LANG=gd_GB.UTF-8
LC_CTYPE="gd_GB.UTF-8"
LC_NUMERIC=gd_GB.UTF-8
LC_TIME=gd_GB.UTF-8
LC_COLLATE="gd_GB.UTF-8"
LC_MONETARY=gd_GB.UTF-8
LC_MESSAGES="gd_GB.UTF-8"
LC_PAPER=gd_GB.UTF-8
LC_NAME=gd_GB.UTF-8
LC_ADDRESS=gd_GB.UTF-8
LC_TELEPHONE=gd_GB.UTF-8
LC_MEASUREMENT=gd_GB.UTF-8
LC_IDENTIFICATION=gd_GB.UTF-8
LC_ALL=
You can update /etc/default/locale manually like this:
sudo update-locale LANGUAGE=gd:en_GB:en
grep to the rescue - the following 2 files need to be edited with sudo gedit to remove the locale:
/etc/default/locale
/home/<user>/.pam_environment
Did you try reconfigure? if not, then try this -
sudo locale-gen “en_US.UTF-8”
Shaze
  • 426
