I think that my printer stopped working with the switch to gnome 3 or unity. Yes I have tried 32 and 64 bit os's. Here is the driver
In order to actually install the driver, you need to extract it and then open up terminal and type sudo and then a space. Then drag the script into the terminal window. Here is what it said in the diver install window:
Extracting file: printdriver.te
Extracting file: lexmark-08z-series-driver-1.0-1.i386.deb
Extracting file: launcher.c
Extracting file: launcherfallendohingy@Ubuntu-Inspiron-15R:~$ sudo '/home/fallendohingy/Downloads/lexmark-08z-series-driver-1.0-1.i386.deb.sh'
[sudo] password for fallendohingy:
Verifying archive integrity... All good.
Uncompressing  nixstaller..............................................................
Collecting info for this system...
Operating system: linux
CPU Arch: x86_64
Warning: No installer for "x86_64" found, defaulting to x86...
TRACKING IDENT = 170209
cpu speed = 2394 MHz
ram size = 3762.69921875 MB
hd avail = 74348 MB
(gtk:17645): GdkPixbuf-WARNING **: Cannot open pixbuf loader module file '/usr/lib/i386-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders.cache': No such file or directory
/usr/lib/gio/modules/libgvfsdbus.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
Extracting file: lsbrowser
Extracting file: lsusbdevice
Using dpkg installation
Execute: dpkg -i --force-architecture lexmark-08z-series-driver-1.0-1.i386.deb > /tmp/selfgz17540/pkg/files/dpkg_msgs
Execute: rm lexmark-08z-series-driver-1.0-1.i386.deb
Execute: /sbin/udevadm control --reload-rules
Successfully installed the .deb Lexmark drivers.
Jorge Castro
  • 73,717
This should work:
  1. sudo apt-get install lzma
  2. sudo apt-get install ia32-libs
  3. tar -zxvf lexmark-08z-series-driver-1.0-1.i386.deb.sh.tar.gz
  4. ./lexmark-08z-series-driver-1.0-1.i386.deb.sh --noexec --target lexmark
  5. tar xvf lexmark/instarchive_all --lzma
  6. dpkg-deb -I lexmark-08z-series-driver-1.0-1.i386.deb
  7. mkdir raw-lexmark-archive
  8. dpkg-deb -e lexmark-08z-series-driver-1.0-1.i386.deb raw-lexmark-archive/DEBIAN
  9. dpkg-deb -X lexmark-08z-series-driver-1.0-1.i386.deb raw-lexmark-archive
  10. cp raw-lexmark-archive/DEBIAN/control raw-lexmark-archive/DEBIAN/control.orig
  11. sed "/^ $/d" raw-lexmark-archive/DEBIAN/control.orig > raw-lexmark-archive/DEBIAN/control
  12. rm raw-lexmark-archive/DEBIAN/control.orig
  13. cat raw-lexmark-archive/DEBIAN/control
  14. dpkg-deb -b ./raw-lexmark-archive New-lexmark-08z-series-driver-1.0-1.i386.deb.deb
  15. sudo dpkg -i New-lexmark-08z-series-driver-1.0-1.i386.deb.deb
To remove the package run: sudo dpkg -P lexmark-08z-series-driver:i386
Jakob
  • 10,789
Racio
  • 86
Why not juts give a try to install the package like this:
gdk-pixbuf-query-loaders > /etc/gtk-2.0/gdk-pixbuf.loaders
or
touch /var/adm/SuSEconfig/run-gtk ; SuSEconfig
There is a bug for same reported here and seems it has not been solved till now. https://bugs.launchpad.net/ubuntu/+source/gdk-pixbuf/+bug/619003
ashutosh
  • 1,302
