As per title, I'd like to install the development version (4.13) of xfwm4 insfead of the regular 4.12 since I've found out that it now supports vsync and opengl and thus removes tearing completely (i.e. no more need for Compton). Unfortunately the only way to install it seems to be from source but, while that's not usually a problem, I've read somewhere (I can't find it anymore) that I'd have to remove xfwm4 4.12 to install 4.13, and that worried me a bit. Also I tried looking something up on askubuntu but only got this question, upgrade xfce4 applications to the latest versions , that doesn't solve my "problem".
So the question is: is there a step-by-step guide or ppa that can ease the installation process? I know that arch has xfwm4-git in the aur but I can't seem yo find anything similar for Ubuntu. Thank you in advance for any help.
dsSTORM
  • 1,880
From Xubuntu's QA Experimental PPA
As mentioned by DK Bose, xfwm4-4.13 is available in the Xubuntu Experimental Repository. This might not be the bleeding edge release but allows for an easier install
sudo add-apt-repository ppa:xubuntu-dev/experimental
sudo apt-get update
and install it
sudo apt-get install xfwm4
From Debian Experimental
xfwm4-4.13 is available in the Debian Experimental Repository and is always the bleeding edge version that is installable from debian experimental. Note that this release might be unstable and possibly unusable. And since ubuntu uses the same packaging system (apt) as debian, one can add that to their sources and it would work.
This is however not recommended as the precompiled packages present in experimental would cause conflicts with the current versions of the packages in the ubuntu repositories, hence it's best to use apt's build-from-source features to get only xfwm4 and it's dependencies
To do this, open up your /etc/apt/sources.list and add this line
deb-src http://httpredir.debian.org/debian/ experimental main contrib non-free
now on the terminal, run the following commands to add the keys necessary for apt to trust the repository
gpg --keyserver pgpkeys.mit.edu --recv-key 8B48AD6246925553 7638D0442B90D010 04EE7237B7D453EC
gpg -a --export 8B48AD6246925553 7638D0442B90D010 04EE7237B7D453EC| sudo apt-key add -
now run
sudo apt-get update
to build all the dependencies for xfwm4
sudo apt-get build-dep xfwm4
and then to install it
sudo apt-get source --compile xfwm4
Amith KK
  • 13,547
