15
When the laptop (Dell Vostro 15) wakes from suspend the mouse cursor can be moved with the touchpad at the login/lock screen, but once back in to the session does not move it. At this point plugging in an external USB mouse works fine. The touchpad works after a reboot, until suspending.
andrew.46
  • 39,359
Reloading the touchpad / mouse driver after resuming from suspend works in most cases.
Run sudo -H gedit /lib/systemd/system-sleep/touchpad
Copy and paste in these lines:
#!/bin/bash
if [[ $1 == post ]]; then
    modprobe -r psmouse
    modprobe psmouse
fi
Save the file and exit.
Now make it a program by setting the execution bit:
chmod a+x /lib/systemd/system-sleep/touchpad
You will need to reboot for changes to take effect.
