pm@pm-desktop:~$ sudo lsblk -f
NAME           FSTYPE  LABEL UUID                                   MOUNTPOINT
sdb
└─sdb1         ntfs          80060C87060C8100                       /media/pm/80
sr0
sda
├─sda2
├─sda5         crypto_       e47293da-ef9b-4299-a0b5-e46339213365
│ └─sda5_crypt LVM2_me       hoVHG1-FRUq-b6x1-dLl1-B1i8-8joH-MAKNkG
    pm@pm-desktop:~$ sudo lsblk -m
NAME                      SIZE OWNER GROUP MODE
sdb                      14.9G root  disk  brw-rw----
└─sdb1                   14.9G root  disk  brw-rw----
sr0                      1024M root  cdrom brw-rw----
sda                     465.8G root  disk  brw-rw----
├─sda2                      1K root  disk  brw-rw----
├─sda5                  465.3G root  disk  brw-rw----
│ └─sda5_crypt          465.3G root  disk  brw-rw----
│   ├─ubuntu--vg-root   463.3G root  disk  brw-rw----
│   └─ubuntu--vg-swap_1     2G root  disk  brw-rw----
└─sda1                    487M root  disk  brw-rw----
│   ├─ubuntu--vg-root
│   │          ext4          39a158a9-1eec-40d7-9edd-6c659f296210   /
│              swap          0f5d2da1-3bbe-439e-8b20-9097be917a36   [SWAP]
└─sda1         ext2          b76e49df-ef33-41cd-9201-dbc718f40ecc   /boot
pm@pm-desktop:~$ sudo parted -ls
Model: ATA ST3500418AS (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type      File system  Flags
 1      1049kB  512MB  511MB  primary   ext2         boot
 2      513MB   500GB  500GB  extended
 5      513MB   500GB  500GB  logical
Warning: Unable to open /dev/sdb read-write (Read-only file system).  /dev/sdb has been opened read-only.
Model: SanDisk Cruzer Switch (scsi)
Disk /dev/sdb: 16.0GB
Disk Flags:
 1      1049kB  16.0GB  16.0GB  primary  ntfs
Model: Linux device-mapper (linear) (dm)
Disk /dev/mapper/ubuntu--vg-root: 497GB
Partition Table: loop
Disk Flags:
Number  Start  End    Size   File system  Flags
 1      0.00B  497GB  497GB  ext4
Disk /dev/mapper/ubuntu--vg-swap_1: 2110MB
Disk Flags:
 1      0.00B  2110MB  2110MB  linux-swap(v1)
Error: /dev/mapper/sda5_crypt: unrecognised disk label
Model: Linux device-mapper (crypt) (dm)
Disk /dev/mapper/sda5_crypt: 500GB
Partition Table: unknown
Disk Flags:
pm@pm-desktop:~$ df -h
Filesystem                   Size  Used Avail Use% Mounted on
udev                         961M     0  961M   0% /dev
tmpfs                        198M  6.2M  192M   4% /run
/dev/mapper/ubuntu--vg-root  456G   16G  418G   4% /
tmpfs                        987M   19M  969M   2% /dev/shm
tmpfs                        5.0M  4.0K  5.0M   1% /run/lock
tmpfs                        987M     0  987M   0% /sys/fs/cgroup
/dev/sda1                    472M  136M  312M  31% /boot
tmpfs                        198M   72K  198M   1% /run/user/1000
/dev/sdb1                     15G  8.7G  6.3G  59% /media/pm/80060C87060C8100
sudodus
  • 47,684
pr0pm
The USB pendrive is seen like this:
$ sudo parted -ls
Disk Flags:
and
$ sudo lsblk -f
sdb
└─sdb1         ntfs          80060C87060C8100                       /media/pm/80...
sr0
sudo lsblk -m
and is mounted as
$ df -h
with read-only permissions. There can be different reasons for the read-only status.
If there are important files on the USB pendrive, please back them up (copy them to another drive) before you start any repair actions.
Maybe the NTFS file system is damaged and needs to be repaired with Windows tools, either the graphical tool in Windows or with
chkdsk /f X:
where X: is its volume ID as seen by Windows. See this link for more details,
Repair the partition table and file system of a pendrive
After trying to repair the file system, you can try again in Ubuntu. If it still does not want to mount it read-write, you can try according to the following AskUbuntu answer,
Mount NTFS partition in a USB drive with custom permissions and owner
sudodus
  • 47,684
