I need help figuring out the best practices to execute those commands in bash.
It's a command that sends a text, and I need to repeat this command for several phone numbers and for several dates... about 250 times in total. The command returns something like this {"creditsUsed":1.00,"snapshotId":107416458} if it went well. An error code otherwise.
curl -X POST \
-H "X-Primotexto-ApiKey: 784155c6a3c9ceed9d0a4d1ffdb67466" \
-H "Content-Type: application/json" \
-d '{"number":"+317877592979" , "message":"test\nother line" , "sender":"myCompany" , "date": 1539272220000}' \
https://api.primotexto.com/v2/notification/messages/send;
curl -X POST \
-d '{"number":"+317877574678" , "message":"test2\nother line" , "sender":"myCompany" , "date": 1539272220001}' \
curl -X POST \
-d '{"number":"+317877574676" , "message":"test3\nother line" , "sender":"myCompany" , "date": 1539272220002}' \
Should I end it with ; or && ?
Should I write a script ?
Can I do something better with json ?
EDIT maybe I could build a json file like this :
    "number":"+336770002979",
    "message":"La plupart\ntest",
    "sender":"BEinstitute",
    "date": 1539286620000
    "number":"+336600000780",
and the run through each object with curl. Any idea how to do this ?
$ curl -X POST -H "X-Primotexto-H "Content-Type: application/json" -d @json.json https://api.primotexto.com/v2/notification/messages/send;
only reads the first object.
