I am having the good old unmet dependency cancer for hours and I've asked about this in ROSAnswers, where I was told that it is an Ubuntu problem hence my question here.
When I try to run the following:
sudo apt-get install ros-kinetic-desktop-full
I get:
Reading package lists... Done
Building dependency tree
ros-kinetic-desktop-full : Depends: ros-kinetic-desktop but it is not going to be installed
Depends: ros-kinetic-perception but it is not going to be installed
Depends: ros-kinetic-simulators but it is not going to be installed
Depends: ros-kinetic-urdf-tutorial but it is not going to be installed
So, obviously, I won't sit and try them one by one as this is not really an intelligent way of solving this.
So, I rather did:
sudo aptitude install ros-kinetic-desktop-full
to see the big picture, and I got the following output:
Building dependency tree...
Reading state information...
Reading extended state information...
Initializing package states...
Building tag database...
The following NEW packages will be installed:
== [tons of stuff which I cannot copy due to character limit]==
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) libvtk6-dev [Not Installed]
2) libvtk6-java [Not Installed]
3) libvtk6-qt-dev [Not Installed]
4) libvtk6.2 [Not Installed]
5) libvtk6.2-qt [Not Installed]
6) python-vtk6 [Not Installed]
7) ros-kinetic-actionlib [Not Installed]
8) ros-kinetic-actionlib-msgs [Not Installed]
9) ros-kinetic-actionlib-tutorials [Not Installed]
10) ros-kinetic-bond [Not Installed]
11) ros-kinetic-bond-core [Not Installed]
12) ros-kinetic-bondcpp [Not Installed]
13) ros-kinetic-bondpy [Not Installed]
14) ros-kinetic-camera-calibration [Not Installed]
15) ros-kinetic-camera-calibration-parsers [Not Installed]
16) ros-kinetic-camera-info-manager [Not Installed]
17) ros-kinetic-catkin [Not Installed]
18) ros-kinetic-class-loader [Not Installed]
19) ros-kinetic-collada-parser [Not Installed]
20) ros-kinetic-collada-urdf [Not Installed]
21) ros-kinetic-common-msgs [Not Installed]
22) ros-kinetic-common-tutorials [Not Installed]
23) ros-kinetic-compressed-depth-image-transport [Not Installed]
24) ros-kinetic-compressed-image-transport [Not Installed]
25) ros-kinetic-control-msgs [Not Installed]
26) ros-kinetic-cpp-common [Not Installed]
27) ros-kinetic-cv-bridge [Not Installed]
28) ros-kinetic-depth-image-proc [Not Installed]
29) ros-kinetic-desktop [Not Installed]
30) ros-kinetic-desktop-full [Not Installed]
31) ros-kinetic-diagnostic-aggregator [Not Installed]
32) ros-kinetic-diagnostic-analysis [Not Installed]
33) ros-kinetic-diagnostic-common-diagnostics [Not Installed]
34) ros-kinetic-diagnostic-msgs [Not Installed]
35) ros-kinetic-diagnostic-updater [Not Installed]
36) ros-kinetic-diagnostics [Not Installed]
37) ros-kinetic-dynamic-reconfigure [Not Installed]
38) ros-kinetic-eigen-conversions [Not Installed]
39) ros-kinetic-eigen-stl-containers [Not Installed]
40) ros-kinetic-executive-smach [Not Installed]
41) ros-kinetic-filters [Not Installed]
42) ros-kinetic-gazebo-dev [Not Installed]
43) ros-kinetic-gazebo-msgs [Not Installed]
44) ros-kinetic-gazebo-plugins [Not Installed]
45) ros-kinetic-gazebo-ros [Not Installed]
46) ros-kinetic-gazebo-ros-pkgs [Not Installed]
47) ros-kinetic-gencpp [Not Installed]
48) ros-kinetic-geneus [Not Installed]
49) ros-kinetic-genlisp [Not Installed]
50) ros-kinetic-genmsg [Not Installed]
51) ros-kinetic-gennodejs [Not Installed]
52) ros-kinetic-genpy [Not Installed]
53) ros-kinetic-geometric-shapes [Not Installed]
54) ros-kinetic-geometry [Not Installed]
55) ros-kinetic-geometry-msgs [Not Installed]
56) ros-kinetic-geometry-tutorials [Not Installed]
57) ros-kinetic-gl-dependency [Not Installed]
58) ros-kinetic-image-common [Not Installed]
59) ros-kinetic-image-geometry [Not Installed]
60) ros-kinetic-image-pipeline [Not Installed]
61) ros-kinetic-image-proc [Not Installed]
62) ros-kinetic-image-publisher [Not Installed]
63) ros-kinetic-image-rotate [Not Installed]
64) ros-kinetic-image-transport [Not Installed]
65) ros-kinetic-image-transport-plugins [Not Installed]
66) ros-kinetic-image-view [Not Installed]
67) ros-kinetic-interactive-marker-tutorials [Not Installed]
68) ros-kinetic-interactive-markers [Not Installed]
69) ros-kinetic-joint-state-publisher [Not Installed]
70) ros-kinetic-kdl-conversions [Not Installed]
71) ros-kinetic-kdl-parser [Not Installed]
72) ros-kinetic-laser-assembler [Not Installed]
73) ros-kinetic-laser-filters [Not Installed]
74) ros-kinetic-laser-geometry [Not Installed]
75) ros-kinetic-laser-pipeline [Not Installed]
76) ros-kinetic-librviz-tutorial [Not Installed]
77) ros-kinetic-map-msgs [Not Installed]
78) ros-kinetic-message-filters [Not Installed]
79) ros-kinetic-message-generation [Not Installed]
80) ros-kinetic-message-runtime [Not Installed]
81) ros-kinetic-mk [Not Installed]
82) ros-kinetic-nav-msgs [Not Installed]
83) ros-kinetic-nodelet [Not Installed]
84) ros-kinetic-nodelet-core [Not Installed]
85) ros-kinetic-nodelet-topic-tools [Not Installed]
86) ros-kinetic-nodelet-tutorial-math [Not Installed]
87) ros-kinetic-octomap [Not Installed]
88) ros-kinetic-opencv3 [Not Installed]
89) ros-kinetic-orocos-kdl [Not Installed]
90) ros-kinetic-pcl-conversions [Not Installed]
91) ros-kinetic-pcl-msgs [Not Installed]
92) ros-kinetic-pcl-ros [Not Installed]
93) ros-kinetic-perception [Not Installed]
94) ros-kinetic-perception-pcl [Not Installed]
95) ros-kinetic-pluginlib [Not Installed]
96) ros-kinetic-pluginlib-tutorials [Not Installed]
97) ros-kinetic-polled-camera [Not Installed]
98) ros-kinetic-python-orocos-kdl [Not Installed]
99) ros-kinetic-qt-dotgraph [Not Installed]
100) ros-kinetic-qt-gui [Not Installed]
101) ros-kinetic-qt-gui-cpp [Not Installed]
102) ros-kinetic-resource-retriever [Not Installed]
103) ros-kinetic-robot [Not Installed]
104) ros-kinetic-robot-model [Not Installed]
105) ros-kinetic-robot-state-publisher [Not Installed]
106) ros-kinetic-ros [Not Installed]
107) ros-kinetic-ros-base [Not Installed]
108) ros-kinetic-ros-comm [Not Installed]
109) ros-kinetic-ros-core [Not Installed]
110) ros-kinetic-ros-tutorials [Not Installed]
111) ros-kinetic-rosbag [Not Installed]
112) ros-kinetic-rosbag-storage [Not Installed]
113) ros-kinetic-rosbash [Not Installed]
114) ros-kinetic-rosbuild [Not Installed]
115) ros-kinetic-rosconsole [Not Installed]
116) ros-kinetic-rosconsole-bridge [Not Installed]
117) ros-kinetic-roscpp [Not Installed]
118) ros-kinetic-roscpp-core [Not Installed]
119) ros-kinetic-roscpp-serialization [Not Installed]
120) ros-kinetic-roscpp-traits [Not Installed]
121) ros-kinetic-roscpp-tutorials [Not Installed]
122) ros-kinetic-rosgraph-msgs [Not Installed]
123) ros-kinetic-roslang [Not Installed]
124) ros-kinetic-roslaunch [Not Installed]
125) ros-kinetic-roslib [Not Installed]
126) ros-kinetic-roslisp [Not Installed]
127) ros-kinetic-rosmake [Not Installed]
128) ros-kinetic-rosmaster [Not Installed]
129) ros-kinetic-rosmsg [Not Installed]
130) ros-kinetic-rosnode [Not Installed]
131) ros-kinetic-rosout [Not Installed]
132) ros-kinetic-rospy [Not Installed]
133) ros-kinetic-rospy-tutorials [Not Installed]
134) ros-kinetic-rosservice [Not Installed]
135) ros-kinetic-rostest [Not Installed]
136) ros-kinetic-rostime [Not Installed]
137) ros-kinetic-rostopic [Not Installed]
138) ros-kinetic-rosunit [Not Installed]
139) ros-kinetic-roswtf [Not Installed]
140) ros-kinetic-rqt-action [Not Installed]
141) ros-kinetic-rqt-bag [Not Installed]
142) ros-kinetic-rqt-bag-plugins [Not Installed]
143) ros-kinetic-rqt-common-plugins [Not Installed]
144) ros-kinetic-rqt-console [Not Installed]
145) ros-kinetic-rqt-dep [Not Installed]
146) ros-kinetic-rqt-graph [Not Installed]
147) ros-kinetic-rqt-gui [Not Installed]
148) ros-kinetic-rqt-gui-cpp [Not Installed]
149) ros-kinetic-rqt-gui-py [Not Installed]
150) ros-kinetic-rqt-image-view [Not Installed]
151) ros-kinetic-rqt-launch [Not Installed]
152) ros-kinetic-rqt-logger-level [Not Installed]
153) ros-kinetic-rqt-moveit [Not Installed]
154) ros-kinetic-rqt-msg [Not Installed]
155) ros-kinetic-rqt-nav-view [Not Installed]
156) ros-kinetic-rqt-plot [Not Installed]
157) ros-kinetic-rqt-pose-view [Not Installed]
158) ros-kinetic-rqt-publisher [Not Installed]
159) ros-kinetic-rqt-py-common [Not Installed]
160) ros-kinetic-rqt-py-console [Not Installed]
161) ros-kinetic-rqt-reconfigure [Not Installed]
162) ros-kinetic-rqt-robot-dashboard [Not Installed]
163) ros-kinetic-rqt-robot-monitor [Not Installed]
164) ros-kinetic-rqt-robot-plugins [Not Installed]
165) ros-kinetic-rqt-robot-steering [Not Installed]
166) ros-kinetic-rqt-runtime-monitor [Not Installed]
167) ros-kinetic-rqt-rviz [Not Installed]
168) ros-kinetic-rqt-service-caller [Not Installed]
169) ros-kinetic-rqt-shell [Not Installed]
170) ros-kinetic-rqt-srv [Not Installed]
171) ros-kinetic-rqt-tf-tree [Not Installed]
172) ros-kinetic-rqt-top [Not Installed]
173) ros-kinetic-rqt-topic [Not Installed]
174) ros-kinetic-rqt-web [Not Installed]
175) ros-kinetic-rviz [Not Installed]
176) ros-kinetic-rviz-plugin-tutorials [Not Installed]
177) ros-kinetic-rviz-python-tutorial [Not Installed]
178) ros-kinetic-self-test [Not Installed]
179) ros-kinetic-sensor-msgs [Not Installed]
180) ros-kinetic-shape-msgs [Not Installed]
181) ros-kinetic-simulators [Not Installed]
182) ros-kinetic-smach-msgs [Not Installed]
183) ros-kinetic-smach-ros [Not Installed]
184) ros-kinetic-stage [Not Installed]
185) ros-kinetic-stage-ros [Not Installed]
186) ros-kinetic-std-msgs [Not Installed]
187) ros-kinetic-std-srvs [Not Installed]
188) ros-kinetic-stereo-image-proc [Not Installed]
189) ros-kinetic-stereo-msgs [Not Installed]
190) ros-kinetic-tf [Not Installed]
191) ros-kinetic-tf-conversions [Not Installed]
192) ros-kinetic-tf2 [Not Installed]
193) ros-kinetic-tf2-eigen [Not Installed]
194) ros-kinetic-tf2-geometry-msgs [Not Installed]
195) ros-kinetic-tf2-kdl [Not Installed]
196) ros-kinetic-tf2-msgs [Not Installed]
197) ros-kinetic-tf2-py [Not Installed]
198) ros-kinetic-tf2-ros [Not Installed]
199) ros-kinetic-theora-image-transport [Not Installed]
200) ros-kinetic-topic-tools [Not Installed]
201) ros-kinetic-trajectory-msgs [Not Installed]
202) ros-kinetic-turtle-actionlib [Not Installed]
203) ros-kinetic-turtle-tf [Not Installed]
204) ros-kinetic-turtle-tf2 [Not Installed]
205) ros-kinetic-turtlesim [Not Installed]
206) ros-kinetic-urdf [Not Installed]
207) ros-kinetic-urdf-parser-plugin [Not Installed]
208) ros-kinetic-urdf-tutorial [Not Installed]
209) ros-kinetic-vision-opencv [Not Installed]
210) ros-kinetic-visualization-marker-tutorials [Not Installed]
211) ros-kinetic-visualization-msgs [Not Installed]
212) ros-kinetic-visualization-tutorials [Not Installed]
213) ros-kinetic-viz [Not Installed]
214) ros-kinetic-webkit-dependency [Not Installed]
215) ros-kinetic-xacro [Not Installed]
216) ros-kinetic-xmlrpcpp [Not Installed]
217) tcl-vtk6 [Not Installed]
218) vtk6 [Not Installed]
Accept this solution? [Y/n/q/?] Y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 817 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
So I am clueless now, like I have no idea what's wrong or what doesn't work. In all honesty, on no OS I struggled to install something this hard. No offense, but this is just frustrating.
My sources list:
-rw-r--r-- 1 root root 66 Okt 11 14:03 cuda-9-0-local-cublas-performance-update-2.list
-rw-r--r-- 1 root root 66 Okt 11 14:03 cuda-9-0-local-cublas-performance-update-2.list.save
-rw-r--r-- 1 root root 64 Okt 11 14:03 cuda-9-0-local-cublas-performance-update.list
-rw-r--r-- 1 root root 64 Okt 11 14:03 cuda-9-0-local-cublas-performance-update.list.save
-rw-r--r-- 1 root root 38 Okt 11 14:03 cuda-9-0-local.list
-rw-r--r-- 1 root root 38 Okt 11 14:03 cuda-9-0-local.list.save
-rw-r--r-- 1 root root 0 Okt 11 11:55 docker.list
-rw-r--r-- 1 root root 0 Okt 11 11:55 docker.list.save
-rw-r--r-- 1 root root 189 Okt 11 14:03 google-chrome.list
-rw-r--r-- 1 root root 189 Okt 11 14:03 google-chrome.list.save
-rw-r--r-- 1 root root 0 Okt 10 15:46 isv:ownCloud:desktop.list
-rw-r--r-- 1 root root 0 Okt 10 15:46 isv:ownCloud:desktop.list.save
-rw-r--r-- 1 root root 49 Okt 11 14:03 matrix-riot-im.list
-rw-r--r-- 1 root root 49 Okt 11 14:03 matrix-riot-im.list.save
-rw-r--r-- 1 root root 459 Okt 11 14:03 mendeleydesktop.list
-rw-r--r-- 1 root root 459 Okt 11 14:03 mendeleydesktop.list.save
-rw-r--r-- 1 root root 146 Okt 11 14:03 mystic-mirage-ubuntu-pycharm-xenial.list
-rw-r--r-- 1 root root 146 Okt 11 14:03 mystic-mirage-ubuntu-pycharm-xenial.list.save
-rw-r--r-- 1 root root 0 Okt 10 15:43 nvidia-docker.list
-rw-r--r-- 1 root root 0 Okt 10 15:43 nvidia-docker.list.save
-rw-r--r-- 1 root root 130 Okt 11 14:03 peterlevi-ubuntu-ppa-xenial.list
-rw-r--r-- 1 root root 130 Okt 11 14:03 peterlevi-ubuntu-ppa-xenial.list.save
-rw-r--r-- 1 root root 51 Okt 11 14:03 ros-latest.list
-rw-r--r-- 1 root root 51 Okt 11 14:03 ros-latest.list.save
-rw-r--r-- 1 root root 56 Okt 11 14:03 skype-stable.list
-rw-r--r-- 1 root root 56 Okt 11 14:03 skype-stable.list.save
-rw-r--r-- 1 root root 50 Okt 11 14:03 spotify.list
-rw-r--r-- 1 root root 50 Okt 11 14:03 spotify.list.save
I had to remove universe one since it caused the priority (500 vs 1000) issue with the python-catkin-pkg. Apart from that all others are checked on the Ubuntu Software Center.
As for the cat /etc/apt/preferences.d, I have only one file called allow-downgrade with the following content:
Package: *
Pin: release o=Ubuntu
Pin-Priority: 1001
Any way of solving this?
