We tried to increase the size of our 15TB partition with lvresize with the following command:
lvresize --resizefs --size +1T /dev/vg0/mm
No errors were displayed during the operation, but the result was kind of a catastrophe. No files were visible any more and the whole drive seemed to be empty.
syslog contained the following errors:
inode #2: block 31777: comm ls: bad entry in directory: inode out of bounds - offset=0(0), inode=2, rec_len=12, name_len=1
We managed to umount the partition and the plan was to run fsck to fix it:
$ fsck.ext4 -n /dev/mapper/vg0-mm
e2fsck 1.42.9 (4-Feb-2014)
Superblock has an invalid journal (inode 8).
Clear? no
fsck.ext4: Illegal inode number while checking ext3 journal for /dev/mapper/vg0-mm
/dev/mapper/vg0-mm: ********** WARNING: Filesystem still has errors **********
$ fsck.ext4 -v /dev/mapper/vg0-mm
Clear<y>? yes
*** ext3 journal has been deleted - filesystem is now ext2 only ***
Corruption found in superblock. (inodes_count = 0).
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
/dev/mapper/vg0-mm: ***** FILE SYSTEM WAS MODIFIED *****
Ok, then next trying to list available alternate superblocks:
$ mke2fs -n /dev/mapper/vg0-mm
mke2fs 1.42.9 (4-Feb-2014)
mke2fs: Size of device (0x100000000 blocks) /dev/mapper/vg0-mm too big to be expressed in 32 bits using a blocksize of 4096.
So it looks like we managed to accidentally go over the 16TB limit with lvresize and our ext4fs didn't have the 64-bit feature flag enabled.
After that we tried to decrease size back to below the 16TB limit, but resize2fs doesn't work either, because it thinks partition is (obviously) dirty and doesn't want to do anything with it.
Any recommendations which direction to take next? Run resize with force or trying to enable the 64-bit feature flag? Something else?
dumpe2fs displays this (among other info):
Inode count: 0
Block count: 4294967295
Block size: 4096
Relevant version info:
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.5 LTS"
e2fsprogs version: 1.42.9-3ubuntu1.3 amd64
Kernel version: 3.13.0-147-generic
UPDATE: After reading through some source code we found root cause for the problem: https://github.com/torvalds/linux/commit/4f2f76f751433908364ccff82f437a57d0e6e9b7
The question still remains, how to recover from the situation where inode count has been reset to 0, thanks to the overflow bug.
