I am trying to open a .pdf file with FoxitReader from the terminal.
The following works on the terminal:
/opt/foxitsoftware/foxitreader/FoxitReader "Document.pdf"
But this doesn't:
/opt/foxitsoftware/foxitreader/FoxitReader "Document.pdf /A page=5" It launches the FoxitReader GUI application, displaying "the file could not be found". The document has more than 5 pages.
  • Foxit Reader version is 2.4.1.0609
  • Ubuntu 16.04
is this option not available for linux systems? Did the syntax change? Do I need to install a plugin?
I also tried
/opt/foxitsoftware/foxitreader/FoxitReader -h
/opt/foxitsoftware/foxitreader/FoxitReader --help
but it fails to open these, too :(
Edit: I attempted the same in Adobe Acrobat Reader
/opt/Adobe/Reader9/bin/acroread /A "page=3" "Document.pdf"
with the same result. As always, instructions are documented for windows. I tried a couple of other PDF viewer now...
is there any free PDF reader able to:
  • run in linux
  • open PDF at a specific page
  • highlight text
  • display page in full view (optional)
thank you
Evince is a PDF viewer able to open PDF files at a specific page using the terminal with the following command:
evince -i 5 "path/to/document.pdf"
where -i option specifies the page of the document, 5 in this example, and the second argument specifies the path to the document to open.
Okular is a PDF viewer able to open PDF files at a specific page using the terminal with the following command:
okular -p 5 "path/to/document.pdf"
where -p option specifies the page of the document, 5 in this example, and the second argument specifies the path to the document to open.
Acrobate Reader is a PDF viewer able to open PDF files at a specific page using the terminal with the following command:
/opt/Adobe/Reader9/bin/acroread /a "page=5" "path/to/document.pdf"
where page=5 is the argument that specifies the page of the document, 5 in this example, and the second argument specifies the path to the document to open.
The Firefox PDF viewer will open at a page number by appending #page= followed by the page number to the URL, for example
firefox "file://$PWD/myfile.pdf#page=150"
The quotes are necessary if there is a space in your current path name. I like to use symbolic links and this won't work from the shell if the file is a symbolic link, but this does
firefox "file://$(realpath myfile.pdf)#page=150"
Liam
  • 131
