Problem solved..by changing the source for 16.04 to the one for 18.04.
I have met some dependency problems when trying to install applications with apt:
$ sudo apt install vim
Reading package lists... Done
Building dependency tree
 vim : Depends: vim-common (= 2:7.4.1689-3ubuntu1.2) but 2:8.0.1453-1ubuntu1 is to be installed
When I tried to install aptitude and then install vim by aptitude, to solve the dependency problem, it told me that apt would be removed:
$ sudo apt-get install aptitude
The following additional packages will be installed:
  aptitude-common libboost-iostreams1.58.0 libcwidget3v5 libsigc++-2.0-0v5
  libxapian22v5
Suggested packages:
  apt-xapian-index aptitude-doc-en | aptitude-doc debtags tasksel
  libcwidget-dev xapian-tools
The following packages will be REMOVED:
  apt apt-utils ubuntu-desktop ubuntu-minimal ubuntu-release-upgrader-gtk
  update-manager update-notifier update-notifier-common
The following NEW packages will be installed:
  aptitude aptitude-common libboost-iostreams1.58.0 libcwidget3v5
  libsigc++-2.0-0v5 libxapian22v5
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  apt
0 upgraded, 6 newly installed, 8 to remove and 13 not upgraded.
Need to get 2,974 kB of archives.
After this operation, 4,842 kB of additional disk space will be used.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
 ?] ^C
Then when I tried to install vim via aptitude, it showed the error that it couldn't find some folder of apt...
I have asked my roommate and he said apt and aptitude don't conflict with each other! So is it true that I can install aptitude without removing apt? and how?
Updated after running apt -f install:
cky@cky:~$ sudo apt update
Hit:1 https://mirrors.ustc.edu.cn/ubuntu xenial InRelease
Hit:2 https://mirrors.ustc.edu.cn/ubuntu xenial-security InRelease
Hit:3 https://mirrors.ustc.edu.cn/ubuntu xenial-updates InRelease
Hit:4 https://mirrors.ustc.edu.cn/ubuntu xenial-backports InRelease
13 packages can be upgraded. Run 'apt list --upgradable' to see them.
cky@cky:~$ sudo apt -f install
0 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
But it dosen't help much, the problem is still the same as before. The sources.list has been changed to a faster one, can that has something to do with the problem?
Here's the sources.list
cky@cky:~$ sudo cat /etc/apt/sources.list
deb https://mirrors.ustc.edu.cn/ubuntu/ xenial main restricted universe multiverse
deb-src https://mirrors.ustc.edu.cn/ubuntu/ xenial main restricted universe multiverse
deb https://mirrors.ustc.edu.cn/ubuntu/ xenial-security main restricted universe multiverse
deb-src https://mirrors.ustc.edu.cn/ubuntu/ xenial-security main restricted universe multiverse
deb https://mirrors.ustc.edu.cn/ubuntu/ xenial-updates main restricted universe multiverse
deb-src https://mirrors.ustc.edu.cn/ubuntu/ xenial-updates main restricted universe multiverse
deb https://mirrors.ustc.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse
deb-src https://mirrors.ustc.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse
## Not recommended
# deb https://mirrors.ustc.edu.cn/ubuntu/ xenial-proposed main restricted universe multiverse
# deb-src https://mirrors.ustc.edu.cn/ubuntu/ xenial-proposed main restricted universe multiverse
cky@cky:~$ sudo cat /etc/apt/sources.list.d/*
cat: '/etc/apt/sources.list.d/*': No such file or directory
It's too slow using the default source xD I'm trying other possible sources
19% [21 Packages 269 kB/1,019 kB 26%]                       15.3 kB/s 45min 35s
Zanna
  • 72,312
Duuang
Good on you for paying attention to the warning!
Your roommate is correct - there is something very wrong. This is how an aptitude install should look:
$ sudo apt install aptitude
The following package was automatically installed and is no longer required:
  libssl-doc
Use 'sudo apt autoremove' to remove it.
  aptitude-common libcwidget3v5
Suggested packages:
  aptitude-doc-en | aptitude-doc apt-xapian-index debtags tasksel
  libcwidget-dev
  aptitude aptitude-common libcwidget3v5
0 to upgrade, 3 to newly install, 0 to remove and 0 not to upgrade.
Need to get 2,569 kB of archives.
After this operation, 10.9 MB of additional disk space will be used.
Do you want to continue? [Y/n]
First thing I notice is that you are trying to install libboost-iostreams1.58.0. I already have libboost-iostreams1.65.1 installed, so my guess is you haven't yet run apt-get update. Please do that first so you know you're getting an up-to-date reference of the repository and correct versions of all the software packages.
Then, from your earlier line:
I think you may have a package that has not completed its installation. Try running:
apt -f install
UPDATE
As @user535733 guessed, the OP's repositories were incorrect. Their repositories in /etc/apt/sources.d/ didn't match the version of Ubuntu they were running. This is unlikely to happen by mistake but could have happened as a result of an external script if it wasn't deliberate.
