From quite recently my splash screen has started continuously flashing upon boot with command lines.Have a look at this video
The messages that show in between your splash screen are messages that the kernel thinks are important for you to see. It is advised to take note and see if the cause of these messages can be tackled. That might be difficult though, and if your system is otherwise fine when booted, you can just choose to ignore these messages, and not have them appear by changing the log level.
To eliminate display of any kernel messages during boot, proceed as follows:
  • Open the file /etc/default/grub as root user with your text editor. If you use nano, you can open the file as root with the command sudo nano /etc/default/grub
  • Change the line starting with GRUB_CMDLINE_LINUX_DEFAULT= to include the option loglevel=0. For example, in a default Ubuntu install, the line might look like:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Change it to read:
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=0 splash"
Save the file and exit the editor (in case of nano, Ctrl+s Ctrl+x will do.)
  • Update your grub to reflect the changes with the command sudo update-grub
vanadium
  • 97,564
