I found xkill on dashboard and my pointer turned into an "x" sign on clicking it. It doesn't change back when I press Esc.
What does this "x" sign stand for and what does it do?
M.A.K. Ripon
  • 3,409
  • 28
  • 36
xkill is a utility used for force-quitting GUI apps. It is handy when some app isn't responding or is causing your system to work abnormally.
NAME
xkill - kill a client by its X resource
DESCRIPTION
Xkill is a utility for forcing the X server to close connections to clients. This program is very dangerous, but is useful for aborting programs that have displayed undesired windows on a user's screen. If no resource identifier is given with -id, xkill will display a special cursor as a prompt for the user to select a window to be killed. If a pointer button is pressed over a non-root window, the server will close its connection to the client that created the window.
To use it quickly you can use Alt+F2 and enter xkill and hit Enter. Alternatively, you can also type the same in Terminal. You can also define a keyboard shortcut in Settings → Devices → Keyboard to use xkill.
Your cursor will turn into cross sign and forcefully terminate (finishes the game (what I think) of) the app.
Zanna
  • 72,312
Kulfy
  • 18,154
