Why doesn't right-clicking and selecting "Open Terminal" in Desktop set the path of the terminal to the Desktop? On the other hand doing the same thing from other directories sets the path as expected.
Asked
Active
Viewed 396 times
This can be changed in dconf editor by changing org > gnome > nautilus > preferences > desktop-is-home-dir
Edit: It appears this functionality was removed with this code change in gnome-terminal
static inline gboolean
desktop_opens_home_dir (TerminalNautilus *nautilus)
#if 0
return _client_get_bool (gconf_client,
"/apps/nautilus-open-terminal/desktop_opens_home_dir",
NULL);
#endif
return TRUE;
Recently they appear to be changing this, but it's unclear if the functionality will return:
Kristopher Ives
- 5,669
Your Desktop is managed by your desktop environment, and not directly by your file manager, which is why you see two different results.
Your desktop environment (right-click > "Open Terminal") opens a terminal window at $HOME.
Your file manager (right-click > Open in Terminal) opens a terminal window at $PWD.
Tom Brossman
- 13,297
