-1
Possible Duplicate:
How do I reset my Unity configuration?
I have an Acer Aspire 5733Z-4851 laptop running Ubuntu 11.10.
I install CCSM back when I installed Ubuntu on the system. One day I was playing around with the different settings, when it seemed like the system locked up.
After restart of the computer; when trying to log into Unity 3D, the only thing that comes up after the desktop pattern is the menu bar that is normally hidden when Unity starts up.
It stays up, but the panel on the left hand side never comes up, nor do the icons at the top right of the menu bar.
The only way to shut the system down, or restart is to press the power button and bring up the menu.
I will note that Unity 2D boots up perfectly fine. I have tried to repair broken packages, but there does not seem to be any. I have tried both synaptic and recovery console. I just managed to get through a major update, that updated the kernal, and Unity. This did not fix the issue. I have also since removed CCSM hoping that would resolve the issue.
I imagine that when I upgrade the machine to 12.04 that it would fix the issue, since when that happens basically the entire system would be replaced.
Do any of you have any other things I can try to get the 3d environment working correctly again?
So, you were messing with CCSM and Unity 2D works. Well, one of the most common mistakes is to disable the Unity plugin in ccsm.
From the Unity 2D you can configure ccsm and enable that plugin again.
Or you can simply try to run the command
unity --reset
GalmWing
  • 380
