I'm getting a networking issue that I'm having a very hard time diagnosing.
About two or three times a day, networking will just stop working completely. By this I mean ping returns:
$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
From 192.168.125.134 icmp_seq=1 Destination Host Unreachable
From 192.168.125.134 icmp_seq=2 Destination Host Unreachable
Sometimes running the ip command will just hang. systemctl restart networking has no effect. The only solution is to reboot the machine.
Interestingly, this only happens on my work network, not at home.
I'm running Ubuntu 18.04 (through the upgrade process) on a slightly old (2016?) Dell XPS 13". I have tried newer kernels (currently on 4.16.7-041607-generic) and various wifi drivers. The problem occurs both when running on wifi and when using ethernet.
Any suggestions? Anything I should be looking at?
Also, if anyone can figure out which ucode I should have for my wifi card, I'd be grateful. My wireless card is Intel Corporation Wireless 8260 (rev 3a) and the kernel is 4.16.
Update:
The last time it happened I was still able to run ip route etc. The results seem to indicate I'm losing the connection to the gateway:
$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.125.1 0.0.0.0 UG 20100 0 0 enx00e04c169188
0.0.0.0 192.168.125.1 0.0.0.0 UG 20600 0 0 wlp58s0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 virbr2
$ arp -a
? (172.17.0.2) at 02:42:ac:11:00:02 [ether] on docker0
_gateway (192.168.125.1) at <incomplete> on enx00e04c169188
_gateway (192.168.125.1) at 00:18:0a:02:94:04 [ether] on wlp58s0
$ ping 192.168.125.1
PING 192.168.125.1 (192.168.125.1) 56(84) bytes of data.
From 192.168.125.134 icmp_seq=3 Destination Host Unreachable
Apologies for running route instead of ip route.
Update 2:
ip addr and ip route both started hanging again. Here's the output from strace:
$ strace ip route
socket(AF_NETLINK, SOCK_RAW|SOCK_CLOEXEC, NETLINK_ROUTE) = 3
setsockopt(3, SOL_SOCKET, SO_SNDBUF, [32768], 4) = 0
setsockopt(3, SOL_SOCKET, SO_RCVBUF, [1048576], 4) = 0
setsockopt(3, SOL_NETLINK, NETLINK_EXT_ACK, [1], 4) = 0
bind(3, {sa_family=AF_NETLINK, nl_pid=0, nl_groups=00000000}, 12) = 0
getsockname(3, {sa_family=AF_NETLINK, nl_pid=7214, nl_groups=00000000}, [12]) = 0
sendto(3, {{len=40, type=RTM_GETROUTE, flags=NLM_F_REQUEST|NLM_F_DUMP, seq=1539085900, pid=0}, {rtm_family=AF_INET, rtm_dst_len=0, rtm_src_len=0, rtm_tos=0, rtm_table=RT_TABLE_UNSPEC, rtm_protocol=RTPROT_UNSPEC, rtm_scope=RT_SCOPE_UNIVERSE, rtm_type=RTN_UNSPEC, rtm_flags=0}, {nla_len=0, nla_type=RTA_UNSPEC}}, 40, 0, NULL, 0
I'm starting to think it's a hardware failure in my laptop dock. Previously I had discounted this as the hangs occur whether I use wifi or ethernet through the dock. It's one of the few things that's different between my home setup (which doesn't hang) and my work setup (which does).
Update 3:
I purchased a new usb hub/dock, but it still happens. My original dock can take a 5v power supply, so I'll see if that helps.
Update 4:
Power supply didn't help. But it does seem to have stopped happening since, or at least have reduced significantly in frequency. I didn't update the kernel, but I think Ubuntu pushed a Thunderbolt firmware update for the Dell XPS that may have done the trick.
