I get an error whenever I try to run any of the following commands
sudo apt upgradesudo apt install chrome-gnome-shelldpkg --configure -asudo install -f
(and probably some others)
The error for sudo apt upgrade is here:
intoo@hilavitkutin:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up grub-efi-amd64 (2.02-2ubuntu8.4) ...
dpkg: error processing package grub-efi-amd64 (--configure):
installed grub-efi-amd64 package post-installation script subprocess returned error exit status 10
Setting up gdm3 (3.28.3-0ubuntu18.04.1) ...
dpkg: error processing package gdm3 (--configure):
installed gdm3 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of grub-efi-amd64-signed:
grub-efi-amd64-signed depends on grub-efi-amd64 | grub-pc; however:
Package grub-efi-amd64 is not configured yet.
Package grub-pc is not installed.
dpkg: error processing package grub-efi-amd64-signed (--configure):
dependency problems - leaving unconfigured
Setting up unattended-upgrades (1.1ubuntu1.18.04.5) ...
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package unattended-upgrades (--configure):
installed unattended-upgrades package post-installation script subprocess returned error exit status 10
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of shim-signed:
shim-signed depends on grub-efi-amd64-signed; however:
Package grub-efi-amd64-signed is not configured yet.
dpkg: error processing package shim-signed (--configure):
grub-efi-amd64
gdm3
unattended-upgrades
shim-signed
I have tried to do all I can to fix this problem but nothing that I found on the web worked, because they relied on dpkg --configure -a and that just gives almost the same error as you can see here:
intoo@hilavitkutin:~$ sudo dpkg --configure -a
grub-efi-amd64
gdm3
unattended-upgrades
shim-signed
I also spotted the lines:
I tried sudo apt install grub-pc, but it just gave this:
intoo@hilavitkutin:~$ sudo apt install grub-pc
grub-pc : Depends: grub-common (= 2.02-2ubuntu8) but 2.02-2ubuntu8.4 is to be installed
Depends: grub2-common (= 2.02-2ubuntu8) but 2.02-2ubuntu8.4 is to be installed
Depends: grub-pc-bin (= 2.02-2ubuntu8) but it is not going to be installed
At the end it says that I have broken packages but I have gone into recovery mode and restored broken packages. The first time it got stuck for 3 hours so I rebooted my computer and tried again. That time it didn't have any problems.
Also, judging from the error report, I seem to have some wrong version stuff.
I am using Ubuntu 18.04.
I would really want to get this fixed since I can't even upgrade if it stays broken.
After
sudo su -
cd /boot/efi/EFI
mv ubuntu ubuntu-old
running apt install -f gives this.
root@hilavitkutin:/boot/efi/EFI# apt install -f
grub-efi-amd64
gdm3
unattended-upgrades
shim-signed
