I can't connect to the internet with my Lubuntu 18.04. It shows the wifi adapter with the signal bars and says that it's connected, but Firefox says: can't connect to server and Sudo apt-get update says Failed to Fetch.
Take the following steps:
  • open a terminal by pressing Ctrl+Alt+T
  • In the terminal type:
    ping www.google.com
  • You will probably get time out as reply or not a reply at all
  • Press Ctrl+C to stop the ping command.
  • In the terminal now type:
    ping 1.1.1.1
    This will try to ping Cloudflare's DNS. If you get replies then the problem lies within your DNS server.
If you don't get a reply then you are not connected to the Internet through your router. (which is en issue outside of Ubuntu and off-topic here)
Fabby
  • 35,017
