I use meld for graphical diff comparisons.
I would like to associate .tpp as a C++ source file for syntax highlighting purposes.
How do I do this?
How do I do this?
    Meld uses the Gnome project's GtkSourceView component for syntax highlighting.
In order to change the file associations, edit the following file:
/usr/share/gtksourceview-3.0/language-specs/cpp.lang
Edit the "globs" section under language/metadata/property and add ;*.tpp
<property name="globs">*.cpp;*.cxx;*.cc;*.C;*.c++;*.tpp</property>
    You can create custom lang files in
~/.local/share/gtksourceview-3.0/language-specs/
If the directory does not already exist, you can create it. Then copy the lang file you want to use as a template from
