Yesterday I created an Ubuntu 18.04 droplet, with a MongoDB v4.0.2 image at DigitalOcean and today I checked the /var/log/auth.log file... What I saw is this:
Oct 1 16:16:25 mongodb-server-1 sshd[9171]: Failed password for root from 116.31.116.16 port 61535 ssh2
Oct 1 16:16:30 mongodb-server-1 sshd[9171]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 61535 ssh2]
Oct 1 16:16:30 mongodb-server-1 sshd[9171]: Received disconnect from 116.31.116.16 port 61535:11: [preauth]
Oct 1 16:16:30 mongodb-server-1 sshd[9171]: Disconnected from authenticating user root 116.31.116.16 port 61535 [preauth]
Oct 1 16:16:30 mongodb-server-1 sshd[9171]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:17:01 mongodb-server-1 CRON[9173]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 1 16:17:01 mongodb-server-1 CRON[9173]: pam_unix(cron:session): session closed for user root
Oct 1 16:17:34 mongodb-server-1 sshd[9176]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:17:36 mongodb-server-1 sshd[9176]: Failed password for root from 116.31.116.16 port 60613 ssh2
Oct 1 16:17:40 mongodb-server-1 sshd[9176]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 60613 ssh2]
Oct 1 16:17:40 mongodb-server-1 sshd[9176]: Received disconnect from 116.31.116.16 port 60613:11: [preauth]
Oct 1 16:17:40 mongodb-server-1 sshd[9176]: Disconnected from authenticating user root 116.31.116.16 port 60613 [preauth]
Oct 1 16:17:40 mongodb-server-1 sshd[9176]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:18:43 mongodb-server-1 sshd[9178]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:18:45 mongodb-server-1 sshd[9178]: Failed password for root from 116.31.116.16 port 30163 ssh2
Oct 1 16:18:49 mongodb-server-1 sshd[9178]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 30163 ssh2]
Oct 1 16:18:49 mongodb-server-1 sshd[9178]: Received disconnect from 116.31.116.16 port 30163:11: [preauth]
Oct 1 16:18:49 mongodb-server-1 sshd[9178]: Disconnected from authenticating user root 116.31.116.16 port 30163 [preauth]
Oct 1 16:18:49 mongodb-server-1 sshd[9178]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:19:50 mongodb-server-1 sshd[9183]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:19:53 mongodb-server-1 sshd[9183]: Failed password for root from 116.31.116.16 port 55398 ssh2
Oct 1 16:19:57 mongodb-server-1 sshd[9183]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 55398 ssh2]
Oct 1 16:19:57 mongodb-server-1 sshd[9183]: Received disconnect from 116.31.116.16 port 55398:11: [preauth]
Oct 1 16:19:57 mongodb-server-1 sshd[9183]: Disconnected from authenticating user root 116.31.116.16 port 55398 [preauth]
Oct 1 16:19:57 mongodb-server-1 sshd[9183]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:20:57 mongodb-server-1 sshd[9186]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:20:59 mongodb-server-1 sshd[9186]: Failed password for root from 116.31.116.16 port 24942 ssh2
Oct 1 16:21:04 mongodb-server-1 sshd[9186]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 24942 ssh2]
Oct 1 16:21:05 mongodb-server-1 sshd[9186]: Received disconnect from 116.31.116.16 port 24942:11: [preauth]
Oct 1 16:21:05 mongodb-server-1 sshd[9186]: Disconnected from authenticating user root 116.31.116.16 port 24942 [preauth]
Oct 1 16:21:05 mongodb-server-1 sshd[9186]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:22:15 mongodb-server-1 sshd[9188]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:22:18 mongodb-server-1 sshd[9188]: Failed password for root from 116.31.116.16 port 17758 ssh2
Oct 1 16:22:22 mongodb-server-1 sshd[9188]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 17758 ssh2]
Oct 1 16:22:23 mongodb-server-1 sshd[9188]: Received disconnect from 116.31.116.16 port 17758:11: [preauth]
Oct 1 16:22:23 mongodb-server-1 sshd[9188]: Disconnected from authenticating user root 116.31.116.16 port 17758 [preauth]
Oct 1 16:22:23 mongodb-server-1 sshd[9188]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:23:15 mongodb-server-1 sshd[9190]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:23:17 mongodb-server-1 sshd[9190]: Failed password for root from 116.31.116.16 port 17471 ssh2
Oct 1 16:23:21 mongodb-server-1 sshd[9190]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 17471 ssh2]
Oct 1 16:23:22 mongodb-server-1 sshd[9190]: Received disconnect from 116.31.116.16 port 17471:11: [preauth]
Oct 1 16:23:22 mongodb-server-1 sshd[9190]: Disconnected from authenticating user root 116.31.116.16 port 17471 [preauth]
Oct 1 16:23:22 mongodb-server-1 sshd[9190]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:24:19 mongodb-server-1 sshd[9209]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:24:20 mongodb-server-1 sshd[9209]: Failed password for root from 116.31.116.16 port 37695 ssh2
Oct 1 16:24:25 mongodb-server-1 sshd[9209]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 37695 ssh2]
Oct 1 16:24:26 mongodb-server-1 sshd[9209]: Received disconnect from 116.31.116.16 port 37695:11: [preauth]
Oct 1 16:24:26 mongodb-server-1 sshd[9209]: Disconnected from authenticating user root 116.31.116.16 port 37695 [preauth]
Oct 1 16:24:26 mongodb-server-1 sshd[9209]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:25:26 mongodb-server-1 sshd[9214]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:25:27 mongodb-server-1 sshd[9214]: Failed password for root from 116.31.116.16 port 17403 ssh2
Oct 1 16:25:31 mongodb-server-1 sshd[9214]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 17403 ssh2]
Oct 1 16:25:32 mongodb-server-1 sshd[9214]: Received disconnect from 116.31.116.16 port 17403:11: [preauth]
Oct 1 16:25:32 mongodb-server-1 sshd[9214]: Disconnected from authenticating user root 116.31.116.16 port 17403 [preauth]
Oct 1 16:25:32 mongodb-server-1 sshd[9214]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:26:25 mongodb-server-1 sshd[9367]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Oct 1 16:26:27 mongodb-server-1 sshd[9367]: Failed password for root from 116.31.116.16 port 42236 ssh2
Oct 1 16:26:31 mongodb-server-1 sshd[9367]: message repeated 2 times: [ Failed password for root from 116.31.116.16 port 42236 ssh2]
Oct 1 16:26:32 mongodb-server-1 sshd[9367]: Received disconnect from 116.31.116.16 port 42236:11: [preauth]
Oct 1 16:26:32 mongodb-server-1 sshd[9367]: Disconnected from authenticating user root 116.31.116.16 port 42236 [preauth]
Oct 1 16:26:32 mongodb-server-1 sshd[9367]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=116.31.116.16 user=root
Thousands of connection attempts logs! And it's still going!
I'm the only one with access to the server and the only port I've left open, is 22!
What's happening?
