I'm running Ubuntu 18.04.1 on a server and trying to install this library) but am having trouble as I'm quite new to Ubuntu and the instruction raise errors.
The installation instructions from the project give the commands:
sudo easy_install ebaysdk
or
sudo easy_install https://github.com/timotheus/ebaysdk-python/archive/master.zip
Both of which give the error:
sudo: easy_install: command not found
I haven't been able to pip install it either because it isn't available in Ubuntu packages.
Is there another simple way to install this python package?
Many thanks
Edit: I've not been able to get easy_install to work by following answers in other posts. Is there another way to install from a url?
Zanna
  • 72,312
blountdj
  • 101
You can install the library directly by pulling it from GitHub
git clone https://github.com/timotheus/ebaysdk-python/
Then go into the folder and install it by typing
cd ebaysdk-python && python ./setup.py install
Amith KK
  • 13,547
