I have rootfs / but within that I have /mnt/another_rootfs which contains a second mounted rootfs.
I want to compare the files in them... but when I do somthng like: diff -r / /mnt/another_rootfs I start to get all the mount points being compared (which I am not so interested in) but also the / rootfs will also contain the second mounted /mnt/another_rootfs ... that is causing issues as well.
So I really just want to diff the files that are actually mounted on / vs the files mounted on /mnt/another_rootfs and not recurse into other mounts.
Is that possible?
code_fodder
  • 281
  • 18
A command line solution is easy, when you reverse the question to "I want to diff /mnt/another_rootfs /":
find /mnt/another_rootfs -xdev -type f -print0 | \
    xargs -0 -r $HOME/bin/diffwithslash
Where $HOME/bin/diffwithslash is something like:
#!/bin/bash
while [[ $# -gt 0 ]] ; do
   afile="$1"
   shift
   bfile="${afile#/mnt/another_rootfs}"
   if [[ -f "$afile" ]] && [[ -f "$bfile" ]] ; then
       diff "$bfile" "$afile"
   fi
done
exit 0
waltinator
  • 37,856
You can mount the partition which holds the /-file-system of the currently booted installation to a second mount-point and compare this mount-point with the mount-point of the other /-file-system.
Use lsblk -f to check which partition is mounted at /.
Then mount the partition with
sudo mount -t ext4 /dev/sdXY /mnt (replace XY with the found value)
Compare /mnt with the the folder which is the mount-point of the other /-file-system.
Unmount with sudo umount /mnt
mook765
  • 18,644
