I would like to run the full features of c++20 on g++. However, I need to install g++-9 for this purpose.
Following the installation guides for old versions of g++ do not work for g++-9.
Any hint?
sudo apt install g++-9
Reading package lists... Done
Building dependency tree
E: Unable to locate package g++-9
E: Couldn't find any package by regex 'g++-9'
sudo apt install g++9
Note, selecting 'libconfig9' for regex 'g++9'
Note, selecting 'libaac-tactics-ocaml-ibg92' for regex 'g++9'
Note, selecting 'libounit-ocaml-dev-afg95:i386' for regex 'g++9'
Note, selecting 'libjpeg9-dbg' for regex 'g++9'
Note, selecting 'libjpeg9-dev' for regex 'g++9'
Note, selecting 'libreins-ocaml-dev-rpyg9' for regex 'g++9'
Note, selecting 'libaac-tactics-ocaml-dev-ibg92' for regex 'g++9'
Note, selecting 'libjpeg9' for regex 'g++9'
Note, selecting 'libflac-ocaml-77yg9:i386' for regex 'g++9'
Note, selecting 'libflac-ocaml-dev-77yg9:i386' for regex 'g++9'
Note, selecting 'libaac-tactics-ocaml' instead of 'libaac-tactics-ocaml-ibg92'
Note, selecting 'libaac-tactics-ocaml-dev' instead of 'libaac-tactics-ocaml-dev-ibg92'
Note, selecting 'libreins-ocaml-dev' instead of 'libreins-ocaml-dev-rpyg9'
Note, selecting 'libflac-ocaml:i386' instead of 'libflac-ocaml-77yg9:i386'
Note, selecting 'libflac-ocaml-dev:i386' instead of 'libflac-ocaml-dev-77yg9:i386'
Note, selecting 'libounit-ocaml-dev:i386' instead of 'libounit-ocaml-dev-afg95:i386'
libaac-tactics-ocaml : Depends: libcoq-ocaml-d91z1
Depends: ocaml-base-nox-4.02.3
Recommends: libaac-tactics-coq but it is not going to be installed
libaac-tactics-ocaml-dev : Depends: camlp5-tli55
Depends: libcoq-ocaml-dev-d91z1
Depends: ocaml-nox-4.02.3
libflac-ocaml-dev:i386 : Depends: libogg-ocaml-dev-465c2:i386
Depends: ocaml-nox-4.02.3:i386
Depends: libogg-ocaml-dev:i386 but it is not going to be installed
libounit-ocaml-dev:i386 : Depends: ocaml-nox-4.02.3:i386
libreins-ocaml-dev : Depends: ocaml-nox-4.02.3
