I can't install anything right now (or upgrade anything). When I run `sudo apt-get upgrade I get this list of unmet dependencies. At the end it says
E: Unmet dependencies. Try using -f.
When I try sudo apt-get upgrade -f I get
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following NEW packages will be installed:
  gcc-4.6-base libacl1 libasound2 libasound2-plugins libasyncns0 libatk1.0-0 libattr1 libaudio2 libavahi-client3
  libavahi-common-data libavahi-common3 libc6 libcairo2 libcomerr2 libcups2 libcupsimage2 libcurl3 libdatrie1
  libdb5.1 libdbus-1-3 libdbusmenu-qt2 libdrm-intel1 libdrm-nouveau1a libdrm-radeon1 libdrm2 libexpat1 libffi6
  libflac8 libfontconfig1 libfreetype6 libgcc1 libgcrypt11 libgdbm3 libgdk-pixbuf2.0-0 libgl1-mesa-dri
  libgl1-mesa-glx libglapi-mesa libglib2.0-0 libgnutls26 libgpg-error0 libgssapi-krb5-2 libgtk2.0-0 libice6
  libidn11 libjack-jackd2-0 libjasper1 libjpeg62 libjson0 libk5crypto3 libkeyutils1 libkrb5-3 libkrb5support0
  liblcms1 libldap-2.4-2 libllvm2.9 libmng1 libnspr4 libnspr4-0d libnss3 libnss3-1d libogg0 libpango1.0-0
  libpciaccess0 libpcre3 libpixman-1-0 libpng12-0 libpulse0 libqt4-dbus libqt4-declarative libqt4-network
  libqt4-opengl libqt4-script libqt4-sql libqt4-svg libqt4-xml libqt4-xmlpatterns libqtcore4 libqtgui4 librtmp0
  libsamplerate0 libsasl2-2 libsasl2-modules libsdl1.2debian-alsa libselinux1 libsm6 libsndfile1 libspeexdsp1
  libsqlite3-0 libssl1.0.0 libstdc++6 libtasn1-3 libthai0 libtiff4 libuuid1 libvorbis0a libvorbisenc2 libwrap0
  libx11-6 libxau6 libxcb-render0 libxcb-shm0 libxcb1 libxcomposite1 libxcursor1 libxdamage1 libxdmcp6 libxext6
  libxfixes3 libxft2 libxi6 libxinerama1 libxrandr2 libxrender1 libxss1 libxt6 libxv1 libxxf86vm1 zlib1g
The following packages will be upgraded:
  myunity
1 upgraded, 118 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/43.5 MB of archives.
After this operation, 144 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
E: Could not perform immediate configuration on 'libc6'. Please see man 5 apt.conf under APT::Immediate-Configure for details. (2)
Nothing happens though. I don't really know what's going on, or how to troubleshoot this. I looked at man 5 apt.conf under Immedate-Configure, but it didn't really tell me anything.
I'm kind of skeptical that all these things need to be installed. I think there's just an error reading some package list or something, so it doesn't know what's installed or not. But I could be wrong about that.
How can I fix these dependency issues?
Kris Harper
  • 13,705
I just ran
sudo apt-get -o APT::Immediate-Configure=no upgrade
using someone else's suggestion. After that I ran
sudo apt-get autoremove
and together they seem to have fixed the issue. I'm not sure how it happened though.
Kris Harper
  • 13,705
That suggestion from the tool is a bit ambiguous if not misleading. You are supposed to run sudo apt-get install -f and NOT sudo apt-get upgrade -f.
Read more about the -f option in man apt-get. It is a bit dense, but it says that -f is expected to work with apt-get install and apt-get remove.
I had a similar packages dependencies problem (Ubuntu 12.10). I fixed it by unticking (in the Software Sources Updates tab):" Pre-released updates (quantal-proposed) " and " Unsupported updates (quantal-backports) "
Worked for me!
Some times it's something as easy as that other times? Not so..................
