After upgrading from 17.10 to 18.04, anytime I try and open Ubuntu I am getting the following errors (which are found in my kern.log as well)
Sep 28 15:06:12 aram-UX330UAK kernel: [   15.056052] PKCS#7 signature not signed with a trusted key
Sep 28 15:06:12 aram-UX330UAK kernel: [   15.083938] PKCS#7 signature not signed with a trusted key
Sep 28 15:06:12 aram-UX330UAK kernel: [   15.087645] PKCS#7 signature not signed with a trusted key
Sep 28 15:06:12 aram-UX330UAK kernel: [   15.093293] PKCS#7 signature not signed with a trusted key
In particular, PKCS#7 that seems to be a common problem and not allowing me to display anything. I don't normally use the standard Ubuntu desktop (I use xmonad) but I don't even have access to the login screen (which I assume uses the standard Ubuntu desktop)
I tried a few of the previous things that I saw:
Ubuntu 18.04 Boot hangs at PKCS#7 signature not signed with a trusted key
After upgrade ubuntu 18.04 changed from GUI to Terminal
But problems that I noticed: I don't have nvidia, so I don't know if this is a graphics problem:
$ lspci -v | grep VGA -A 1
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02) (prog-if 00 [VGA controller])
    Subsystem: ASUSTeK Computer Inc. HD Graphics 620
Also double checked and everything seems to be installed. I tried doing an update/upgrade and nothing new happened. I tried reinstalling ubuntu-desktop to no avail.
I do have Windows dual-booted, but I have secure boot disabled (I double and triple checked the bios) so I don't think that's an issue either.
It does give me access to a terminal afterward though and after I log in I noticed the following error:
Failed to connect to X Server.
Cannot open display 'default display'
So it seems like a display issue, but no idea how to procede. I tried reinstalling xmonad to no avail.
Anyone have any ideas how to fix this or what needs to be done so that I get access to things?
--- EDIT ---
Here's my Xorg log as asked for:
[ 12435.612]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 12435.612] X Protocol Version 11, Revision 0
[ 12435.612] Build Operating System: Linux 4.4.0-119-generic x86_64 Ubuntu
[ 12435.612] Current Operating System: Linux aram-UX330UAK 4.13.0-46-generic #51-Ubuntu SMP Tue Jun 12 12:36:29 UTC 2018 x86_64
[ 12435.612] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.13.0-46-generic.efi.signed root=UUID=6919df57-2080-4508-82b7-0ccb1e067b6a ro quiet splash vt.handoff=7
[ 12435.613] Build Date: 13 April 2018  08:07:36PM
[ 12435.613] xorg-server 2:1.19.6-1ubuntu4 (For technical support please see http://www.ubuntu.com/support)
[ 12435.613] Current version of pixman: 0.34.0
[ 12435.613]    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
[ 12435.613] Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 12435.613] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep 28 14:44:15 2018
[ 12435.613] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 12435.614] (==) No Layout section.  Using the first Screen section.
[ 12435.614] (==) No screen section available. Using defaults.
[ 12435.614] (**) |-->Screen "Default Screen Section" (0)
[ 12435.614] (**) |   |-->Monitor "<default monitor>"
[ 12435.614] (==) No device specified for screen "Default Screen Section".
    Using the first device section listed.
[ 12435.614] (**) |   |-->Device "card0"
[ 12435.614] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[ 12435.614] (==) Automatically adding devices
[ 12435.614] (==) Automatically enabling devices
[ 12435.614] (==) Automatically adding GPU devices
[ 12435.614] (==) Automatically binding GPU devices
[ 12435.614] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 12435.614] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 12435.614]    Entry deleted from font path.
[ 12435.615] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 12435.615]    Entry deleted from font path.
[ 12435.615] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 12435.615] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 12435.615] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 12435.615] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    /usr/share/fonts/X11/Type1,
    built-ins
[ 12435.615] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 12435.615] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 12435.615] (II) Loader magic: 0x556a504d8020
[ 12435.615] (II) Module ABI versions:
[ 12435.615]    X.Org ANSI C Emulation: 0.4
[ 12435.615]    X.Org Video Driver: 23.0
[ 12435.615]    X.Org XInput driver : 24.1
[ 12435.615]    X.Org Server Extension : 10.0
[ 12435.616] (++) using VT number 7
[ 12435.616] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 12435.617] (II) xfree86: Adding drm device (/dev/dri/card0) [ 12435.626] (--) PCI:(0:0:2:0) 8086:5916:1043:1520 rev 2, Mem @ 0xee000000/16777216, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072 [ 12435.626] (II) LoadModule: "glx" [ 12435.627] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 12435.628] (II) Module glx: vendor="X.Org Foundation" [ 12435.628] compiled for 1.19.6, module version = 1.0.0 [ 12435.628] ABI class: X.Org Server Extension, version 10.0 [ 12435.628] (II) LoadModule: "intel" [ 12435.629] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so [ 12435.629] (II) Module intel: vendor="X.Org Foundation" [ 12435.629] compiled for 1.19.5, module version = 2.99.917 [ 12435.629] Module class: X.Org Video Driver [ 12435.629] ABI class: X.Org Video Driver, version 23.0 [ 12435.629] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets: i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45, 4 Series, G45/G43, Q45/Q43, G41, B43 [ 12435.630] (II) intel: Driver for Intel(R) HD Graphics [ 12435.630] (II) intel: Driver for Intel(R) Iris(TM) Graphics [ 12435.630] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics [ 12435.630] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20170619 [ 12435.630] (II) intel(0): SNA compiled: xserver-xorg-video-intel 2:2.99.917+git20171229-1 (Timo Aaltonen <tjaalton@debian.org>) [ 12435.630] (II) intel(0): SNA compiled for use with valgrind [ 12435.649] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 620 [ 12435.649] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 2 threads [ 12435.649] (II) intel(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 12435.649] (==) intel(0): Depth 24, (--) framebuffer bpp 32 [ 12435.649] (==) intel(0): RGB weight 888 [ 12435.649] (==) intel(0): Default visual is TrueColor [ 12435.649] () intel(0): Option "Backlight" "intel_backlight" [ 12435.650] (II) intel(0): Output eDP1 has no monitor section [ 12435.650] () intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1 [ 12435.650] (II) intel(0): Enabled output eDP1 [ 12435.650] (II) intel(0): Output HDMI1 has no monitor section [ 12435.650] (II) intel(0): Enabled output HDMI1 [ 12435.650] (--) intel(0): Using a maximum size of 256x256 for hardware cursors [ 12435.650] (II) intel(0): Output VIRTUAL1 has no monitor section [ 12435.650] (II) intel(0): Enabled output VIRTUAL1 [ 12435.650] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0 [ 12435.651] (==) intel(0): TearFree enabled [ 12435.651] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0) [ 12435.651] (==) intel(0): DPI set to (96, 96) [ 12435.651] (II) Loading sub module "dri3" [ 12435.651] (II) LoadModule: "dri3" [ 12435.651] (II) Module "dri3" already built-in [ 12435.651] (II) Loading sub module "dri2" [ 12435.651] (II) LoadModule: "dri2" [ 12435.651] (II) Module "dri2" already built-in [ 12435.651] (II) Loading sub module "present" [ 12435.651] (II) LoadModule: "present" [ 12435.651] (II) Module "present" already built-in [ 12435.651] (==) Depth 24 pixmap format is 32 bpp [ 12435.651] (II) intel(0): SNA initialized with Kabylake (gen9) backend [ 12435.651] (==) intel(0): Backing store enabled [ 12435.651] (==) intel(0): Silken mouse enabled [ 12435.651] (II) intel(0): HW Cursor enabled [ 12435.651] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message. [ 12435.652] (==) intel(0): DPMS enabled [ 12435.652] (==) intel(0): Display hotplug detection enabled [ 12435.652] (II) intel(0): [DRI2] Setup complete [ 12435.652] (II) intel(0): [DRI2] DRI driver: i965 [ 12435.652] (II) intel(0): [DRI2] VDPAU driver: va_gl [ 12435.652] (II) intel(0): direct rendering: DRI2 enabled [ 12435.652] (II) intel(0): hardware support for Present enabled [ 12435.652] (--) RandR disabled [ 12435.657] (II) SELinux: Disabled on system [ 12435.674] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer [ 12435.674] (II) AIGLX: enabled GLX_ARB_create_context [ 12435.674] (II) AIGLX: enabled GLX_ARB_create_context_profile [ 12435.674] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile [ 12435.674] (II) AIGLX: enabled GLX_INTEL_swap_event [ 12435.674] (II) AIGLX: enabled GLX_SGI_swap_control [ 12435.674] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB [ 12435.674] (II) AIGLX: enabled GLX_ARB_fbconfig_float [ 12435.674] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float [ 12435.674] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects [ 12435.674] (II) AIGLX: enabled GLX_ARB_create_context_robustness [ 12435.675] (II) AIGLX: Loaded and initialized i965 [ 12435.675] (II) GLX: Initialized DRI2 GL provider for screen 0 [ 12435.679] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none [ 12435.689] (II) intel(0): Setting screen physical size to 508 x 285 [ 12435.728] (II) config/udev: Adding input device Power Button (/dev/input/event3) [ 12435.728] () Power Button: Applying InputClass "libinput keyboard catchall" [ 12435.728] (II) LoadModule: "libinput" [ 12435.729] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 12435.731] (II) Module libinput: vendor="X.Org Foundation" [ 12435.731] compiled for 1.19.6, module version = 0.27.1 [ 12435.731] Module class: X.Org XInput Driver [ 12435.731] ABI class: X.Org XInput driver, version 24.1 [ 12435.731] (II) Using input driver 'libinput' for 'Power Button' [ 12435.731] () Power Button: always reports core events [ 12435.731] () Option "Device" "/dev/input/event3" [ 12435.732] () Option "_source" "server/udev" [ 12435.732] (II) event3 - Power Button: is tagged by udev as: Keyboard [ 12435.732] (II) event3 - Power Button: device is a keyboard [ 12435.732] (II) event3 - Power Button: device removed [ 12435.752] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3" [ 12435.752] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6) [ 12435.752] () Option "xkb_model" "asus_laptop" [ 12435.752] () Option "xkb_layout" "us" [ 12435.752] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12435.769] (II) event3 - Power Button: is tagged by udev as: Keyboard [ 12435.769] (II) event3 - Power Button: device is a keyboard [ 12435.769] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event6) [ 12435.769] () Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall" [ 12435.769] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control' [ 12435.770] () Asus Wireless Radio Control: always reports core events [ 12435.770] () Option "Device" "/dev/input/event6" [ 12435.770] () Option "_source" "server/udev" [ 12435.770] (II) event6 - Asus Wireless Radio Control: is tagged by udev as: Keyboard [ 12435.770] (II) event6 - Asus Wireless Radio Control: device is a keyboard [ 12435.770] (II) event6 - Asus Wireless Radio Control: device removed [ 12435.824] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input6/event6" [ 12435.824] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7) [ 12435.824] () Option "xkb_model" "asus_laptop" [ 12435.824] () Option "xkb_layout" "us" [ 12435.824] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12435.824] (II) event6 - Asus Wireless Radio Control: is tagged by udev as: Keyboard [ 12435.824] (II) event6 - Asus Wireless Radio Control: device is a keyboard [ 12435.824] (II) config/udev: Adding input device Video Bus (/dev/input/event5) [ 12435.825] () Video Bus: Applying InputClass "libinput keyboard catchall" [ 12435.825] (II) Using input driver 'libinput' for 'Video Bus' [ 12435.825] () Video Bus: always reports core events [ 12435.825] () Option "Device" "/dev/input/event5" [ 12435.825] () Option "_source" "server/udev" [ 12435.825] (II) event5 - Video Bus: is tagged by udev as: Keyboard [ 12435.825] (II) event5 - Video Bus: device is a keyboard [ 12435.825] (II) event5 - Video Bus: device removed [ 12435.876] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5/event5" [ 12435.876] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8) [ 12435.876] () Option "xkb_model" "asus_laptop" [ 12435.876] () Option "xkb_layout" "us" [ 12435.876] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12435.878] (II) event5 - Video Bus: is tagged by udev as: Keyboard [ 12435.878] (II) event5 - Video Bus: device is a keyboard [ 12435.879] (II) config/udev: Adding input device Lid Switch (/dev/input/event0) [ 12435.879] (II) No input driver specified, ignoring this device. [ 12435.879] (II) This device may have been added with another device file. [ 12435.881] (II) config/udev: Adding input device Power Button (/dev/input/event2) [ 12435.881] () Power Button: Applying InputClass "libinput keyboard catchall" [ 12435.881] (II) Using input driver 'libinput' for 'Power Button' [ 12435.882] () Power Button: always reports core events [ 12435.882] () Option "Device" "/dev/input/event2" [ 12435.882] () Option "_source" "server/udev" [ 12435.883] (II) event2 - Power Button: is tagged by udev as: Keyboard [ 12435.883] (II) event2 - Power Button: device is a keyboard [ 12435.883] (II) event2 - Power Button: device removed [ 12435.916] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2" [ 12435.916] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9) [ 12435.916] () Option "xkb_model" "asus_laptop" [ 12435.916] () Option "xkb_layout" "us" [ 12435.916] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12435.917] (II) event2 - Power Button: is tagged by udev as: Keyboard [ 12435.917] (II) event2 - Power Button: device is a keyboard [ 12435.919] (II) config/udev: Adding input device Sleep Button (/dev/input/event1) [ 12435.919] () Sleep Button: Applying InputClass "libinput keyboard catchall" [ 12435.919] (II) Using input driver 'libinput' for 'Sleep Button' [ 12435.919] () Sleep Button: always reports core events [ 12435.919] () Option "Device" "/dev/input/event1" [ 12435.919] () Option "_source" "server/udev" [ 12435.920] (II) event1 - Sleep Button: is tagged by udev as: Keyboard [ 12435.920] (II) event1 - Sleep Button: device is a keyboard [ 12435.920] (II) event1 - Sleep Button: device removed [ 12435.972] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1" [ 12435.972] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10) [ 12435.972] () Option "xkb_model" "asus_laptop" [ 12435.972] () Option "xkb_layout" "us" [ 12435.972] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12435.973] (II) event1 - Sleep Button: is tagged by udev as: Keyboard [ 12435.973] (II) event1 - Sleep Button: device is a keyboard [ 12435.975] (II) config/udev: Adding input device USB2.0 HD UVC WebCam: USB2.0 HD (/dev/input/event15) [ 12435.975] () USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "libinput keyboard catchall" [ 12435.975] (II) Using input driver 'libinput' for 'USB2.0 HD UVC WebCam: USB2.0 HD' [ 12435.975] () USB2.0 HD UVC WebCam: USB2.0 HD: always reports core events [ 12435.975] () Option "Device" "/dev/input/event15" [ 12435.975] () Option "_source" "server/udev" [ 12435.976] (II) event15 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard [ 12435.976] (II) event15 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard [ 12435.976] (II) event15 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed [ 12436.024] () Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input16/event15" [ 12436.024] (II) XINPUT: Adding extended input device "USB2.0 HD UVC WebCam: USB2.0 HD" (type: KEYBOARD, id 11) [ 12436.024] () Option "xkb_model" "asus_laptop" [ 12436.024] () Option "xkb_layout" "us" [ 12436.024] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12436.025] (II) event15 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard [ 12436.025] (II) event15 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard [ 12436.027] (II) config/udev: Adding input device ELAN1300:00 04F3:3028 Touchpad (/dev/input/event8) [ 12436.027] () ELAN1300:00 04F3:3028 Touchpad: Applying InputClass "libinput touchpad catchall" [ 12436.027] () ELAN1300:00 04F3:3028 Touchpad: Applying InputClass "touchpad catchall" [ 12436.027] () ELAN1300:00 04F3:3028 Touchpad: Applying InputClass "Default clickpad buttons" [ 12436.027] (II) LoadModule: "synaptics" [ 12436.027] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so [ 12436.027] (II) Module synaptics: vendor="X.Org Foundation" [ 12436.027] compiled for 1.19.3, module version = 1.9.0 [ 12436.027] Module class: X.Org XInput Driver [ 12436.027] ABI class: X.Org XInput driver, version 24.1 [ 12436.027] (II) Using input driver 'synaptics' for 'ELAN1300:00 04F3:3028 Touchpad' [ 12436.027] () ELAN1300:00 04F3:3028 Touchpad: always reports core events [ 12436.027] () Option "Device" "/dev/input/event8" [ 12436.065] (II) synaptics: ELAN1300:00 04F3:3028 Touchpad: found clickpad property [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: x-axis range 0 - 3208 (res 31) [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: y-axis range 0 - 2206 (res 32) [ 12436.065] (II) synaptics: ELAN1300:00 04F3:3028 Touchpad: device does not report pressure, will use touch data. [ 12436.065] (II) synaptics: ELAN1300:00 04F3:3028 Touchpad: device does not report finger width. [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: buttons: left double triple [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: Vendor 0x4f3 Product 0x3028 [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: invalid pressure range. defaulting to 0 - 255 [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: invalid finger width range. defaulting to 0 - 15 [ 12436.065] () Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0" [ 12436.065] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: touchpad found [ 12436.065] () ELAN1300:00 04F3:3028 Touchpad: always reports core events [ 12436.096] () Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-5/i2c-ELAN1300:00/0018:04F3:3028.0001/input/input9/event8" [ 12436.096] (II) XINPUT: Adding extended input device "ELAN1300:00 04F3:3028 Touchpad" (type: TOUCHPAD, id 12) [ 12436.096] () synaptics: ELAN1300:00 04F3:3028 Touchpad: (accel) MinSpeed is now constant deceleration 2.5 [ 12436.096] () synaptics: ELAN1300:00 04F3:3028 Touchpad: (accel) MaxSpeed is now 1.75 [ 12436.096] () synaptics: ELAN1300:00 04F3:3028 Touchpad: (accel) AccelFactor is now 0.051 [ 12436.097] () ELAN1300:00 04F3:3028 Touchpad: (accel) keeping acceleration scheme 1 [ 12436.097] () ELAN1300:00 04F3:3028 Touchpad: (accel) acceleration profile 1 [ 12436.097] () ELAN1300:00 04F3:3028 Touchpad: (accel) acceleration factor: 2.000 [ 12436.097] () ELAN1300:00 04F3:3028 Touchpad: (accel) acceleration threshold: 4 [ 12436.097] (--) synaptics: ELAN1300:00 04F3:3028 Touchpad: touchpad found [ 12436.099] (II) config/udev: Adding input device ELAN1300:00 04F3:3028 Touchpad (/dev/input/mouse0) [ 12436.099] () ELAN1300:00 04F3:3028 Touchpad: Ignoring device from InputClass "touchpad ignore duplicates" [ 12436.099] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9) [ 12436.100] (II) No input driver specified, ignoring this device. [ 12436.100] (II) This device may have been added with another device file. [ 12436.100] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10) [ 12436.100] (II) No input driver specified, ignoring this device. [ 12436.100] (II) This device may have been added with another device file. [ 12436.101] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event11) [ 12436.101] (II) No input driver specified, ignoring this device. [ 12436.101] (II) This device may have been added with another device file. [ 12436.102] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event12) [ 12436.102] (II) No input driver specified, ignoring this device. [ 12436.102] (II) This device may have been added with another device file. [ 12436.102] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event13) [ 12436.102] (II) No input driver specified, ignoring this device. [ 12436.102] (II) This device may have been added with another device file. [ 12436.103] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event14) [ 12436.103] (II) No input driver specified, ignoring this device. [ 12436.103] (II) This device may have been added with another device file. [ 12436.104] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event7) [ 12436.104] () Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall" [ 12436.104] (II) Using input driver 'libinput' for 'Asus WMI hotkeys' [ 12436.104] () Asus WMI hotkeys: always reports core events [ 12436.104] () Option "Device" "/dev/input/event7" [ 12436.104] () Option "_source" "server/udev" [ 12436.105] (II) event7 - Asus WMI hotkeys: is tagged by udev as: Keyboard [ 12436.105] (II) event7 - Asus WMI hotkeys: device is a keyboard [ 12436.105] (II) event7 - Asus WMI hotkeys: device removed [ 12436.148] () Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input7/event7" [ 12436.148] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 13) [ 12436.148] () Option "xkb_model" "asus_laptop" [ 12436.148] () Option "xkb_layout" "us" [ 12436.148] () Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12436.149] (II) event7 - Asus WMI hotkeys: is tagged by udev as: Keyboard [ 12436.149] (II) event7 - Asus WMI hotkeys: device is a keyboard [ 12436.150] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4) [ 12436.150] () AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall" [ 12436.150] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard' [ 12436.150] () AT Translated Set 2 keyboard: always reports core events [ 12436.150] () Option "Device" "/dev/input/event4" [ 12436.150] () Option "_source" "server/udev" [ 12436.151] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard [ 12436.151] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard [ 12436.151] (II) event4 - AT Translated Set 2 keyboard: device removed [ 12436.188] () Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4" [ 12436.188] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14) [ 12436.188] () Option "xkb_model" "asus_laptop" [ 12436.188] () Option "xkb_layout" "us" [ 12436.188] (*) Option "xkb_options" "lv3:menu_switch,compose:rctrl" [ 12436.189] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard [ 12436.189] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard [ 12436.223] (II) event3 - Power Button: device removed [ 12436.268] (II) event6 - Asus Wireless Radio Control: device removed [ 12436.308] (II) event5 - Video Bus: device removed [ 12436.348] (II) event2 - Power Button: device removed [ 12436.388] (II) event1 - Sleep Button: device removed [ 12436.436] (II) event15 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed [ 12436.516] (II) event7 - Asus WMI hotkeys: device removed [ 12436.556] (II) event4 - AT Translated Set 2 keyboard: device removed [ 12436.588] (II) AIGLX: Suspending AIGLX clients for VT switch [ 12436.668] (II) UnloadModule: "libinput" [ 12436.668] (II) UnloadModule: "libinput" [ 12436.668] (II) UnloadModule: "synaptics" [ 12436.668] (II) UnloadModule: "libinput" [ 12436.668] (II) UnloadModule: "libinput" [ 12436.668] (II) UnloadModule: "libinput" [ 12436.668] (II) UnloadModule: "libinput" [ 12436.668] (II) UnloadModule: "libinput" [ 12436.669] (II) UnloadModule: "libinput" [ 12436.673] (II) Server terminated successfully (0). Closing log file.
Lorenz Keel
  • 9,511
I ended up finding out it was because gdm3 was not loading. I followed this: gdm3 doesn't start in ubuntu 18.04 And it ended up starting to work after two restarts.
