I am trying to install gnupg from source code using the following method:
step 1:
I cd to the uncompressed gunpg-2.2.10
cd Downloads/gnupg-2.2.10
step 2:
I run command :
./configure
step 3:
I run command
make
also I installed the libgcrypt as follow before the previous steps as follow:
step 1:
I cd to the libgcrypt uncompressed folder
step 2:
I run
sudo ./configure
step 3:
I run :
sudo make
step 4:
I run
sudo make install
but every time I go to the folder gnupg-2.2.10/g10 and run
./gpg
I get
 gpg: Fatal: libgcrypt is too old (need 1.7.0, have 1.6.5)
now here is the output of ls /usr/local/lib
libassuan.la        libgcrypt.so.20         libksba.la         libnpth.so.0
libassuan.so        libgcrypt.so.20.2.3     libksba.so         libnpth.so.0.1.2
libassuan.so.0      libgpg-error.la         libksba.so.8       python2.7
libassuan.so.0.8.1  libgpg-error.so         libksba.so.8.11.6  python3.5
libgcrypt.la        libgpg-error.so.0       libnpth.la
libgcrypt.so        libgpg-error.so.0.24.3  libnpth.so
please tell me what are the needed commands to fix this error? and please note I am not linux expert
mark
Try
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
./gpg
