I get this error after using the command:
keagan@KsPc:~$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  libxss1:i386
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  libgles1 libglvnd-dev
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 37 not upgraded.
1 not fully installed or removed.
Need to get 0 B/14.6 kB of archives.
After this operation, 91.1 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 251820 files and directories currently installed.)
Preparing to unpack .../libgles1_1.0.0-2ubuntu2.2_amd64.deb ...
Unpacking libgles1:amd64 (1.0.0-2ubuntu2.2) ...
dpkg: error processing archive /var/cache/apt/archives/libgles1_1.0.0-2ubuntu2.2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1', which is also in package nvidia-340 340.106-0ubuntu3
Preparing to unpack .../libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb ...
Unpacking libglvnd-dev:amd64 (1.0.0-2ubuntu2.2) ...
dpkg: error processing archive /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLESv1_CM.so', which is also in package nvidia-340 340.106-0ubuntu3
Im new to Linux and I have no idea what to do with problems like these Please help
mook765
  • 18,644
here's what worked for me. I am running Ubuntu 18.04 and encountered a similar error.
When the fix-broken command doesn't work,
you can always use dpkg to force an overwrite of the software that isn't working. This worked for me, allowed me to continue to update software on my install, and reboot without a problem. Try at your own risk. :)
sudo dpkg -i --force-overwrite /var/cache/apt/archives/libgles1_1.0.0-2ubuntu2.2_amd64.deb
If that works, try re-running apt fix-install
sudo apt install -f
And then you may need to run this in addition to get the nvidia drivers to upgrade.
sudo dist-upgrade
Let me know how it goes.
Here is a source describing the same method, and another source.
https://bugs.launchpad.net/ubuntu/+source/libglvnd/+bug/1791542
You can either wait for the fix or update as per the link.
The nvidia-340.106 driver will be updated to 340.107
Sima
