I have a directory, and it has many sub-directories.
home/folderA/*
home/folderB/*
What I want to do is to delete all lines that have certain text 'password' in files in each sub-directory.
sed -i '/password/d' *
this command can only work with files and can't go inside directories. I'd be thankful for any advice in how to do this.
muru
  • 207,228
Thwe
  • 13
I would use find with sed like:
find /path/to/source -type f -exec sed '/password/d' {} +
Add -i to sed -i '/password/d' above to write the changes into files in place.
  • the /path/to/source is your directory path that you want to run sed for the files in and its sub-directories.
  • the -type f looks for the files type only.
  • with -exec command {} +, the command will be executed for the files found.
See and read also What is the difference between using '+' (plus) and ';' (semicolon) in -exec command?.
αғsнιη
  • 36,350
