I have a system with Linux Mint and Windows 10 installed on it. My Windows 10 side has the boot drive on a 60gb partition of a 120gb SSD, with the data drive on a 1TB
HDD (this has all my data on it). My Mint side also has the boot drive on a 60gb partition of a 120gb SSD, with the /home partition on a different 1TB HDD (the data on this one can be deleted). I need to replace Mint with Ubuntu, but I want to make sure I don't overwrite my data on Windows 10 data drive. Last time I did this
I guessed and picked the wrong one and lost some files, and I don't want that to happen again. Is there a way I can differentiate between the two hard drives?
Asked
Active
Viewed 2,475 times
Calvin K
- 73
Assuming your disk is smart enabled, you can get a lot of information with smartctl:
$ smartctl -i /dev/sda
If all you want is the drive's serial number, you can filter it:
$ smartctl -i /dev/sda | grep -i serial
Substitute /dev/sda by the name of your devices.
pomsky
- 70,557
