I didn't quite understand how to fix these stuff from other posts. Can someone help me?
W: GPG error: https://dl.winehq.org/wine-builds/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 818A435C5FCBF54A
E: The repository 'https://dl.winehq.org/wine-builds/ubuntu bionic InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
muru
  • 207,228
When you are getting a public key error, the key itself is the last 8 digits of the NO_PUBKEY.
To install it run the following line
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 5FCBF54A
Then rerun your
sudo apt update
Hope this helps!
Terrance
  • 43,712
This is telling you that your repository for Wine is not using code signing and is refusing to update because it doesn't know how to verify the packages from that repository.
You can fix the problem by adding their code signing keys from winehq.org:
wget -nc https://dl.winehq.org/wine-builds/Release.key
sudo apt-key add Release.key
rm Release.key
you can use the command below to add the wine key
sudo apt-key add winehq.key
source is https://wiki.winehq.org/Ubuntu
