I am having problems installing/uninstalling things with apt. I think this is because I have unistalled python and apt is trying to use it. I have miniconda, but when I use apt it is not accessing this miniconda version. How do I make it do so?
More info:
$ ls -l /usr/bin/\*python\*
/usr/bin/python -> /home/neiltheory/miniconda2/bin/python
/usr/bin/python2 -> python2.7
/usr/bin/python2.7
/usr/bin/python3 -> /home/neiltheory/miniconda2/bin/python
/usr/bin/python3.6
/usr/bin/python3.6m
/usr/bin/python3m -> python3.6m
/usr/bin/x86_64-linux-gnu-python2.7-config
/usr/bin/x86_64-linux-gnu-python-config -> x86_64-linux-gnu-python2.7-config
when I do:
 sudo apt remove python3.6
I get a bunch of dpkg errors and a suggestion to do:
apt --fix-broken install
...which also produces a bunch of python errors.
Edit: Solution:
After re building the appropriate system pythons from source code and installing them in the same place apt and dpkg started to behave themselves again. However all was not entirely well - some of my programs which used python just didn't work 100% as they should. Specifically the terminal app terminator continually crashed and a physics program 'MadGraph' didn't function fully either. Not being a python expert and needing desperately to continue my work I nuked the lot, installed a fresh Ubuntu and vowed never to touch the system python installations again. Lesson learned, but perhaps solution not yet found.
I'm not sure of the etiquette for answering ones own question, and I'm not sure if this even constitutes an answer of if it's a further question:
QUESTION: Is there a better way of dealing with this than doing a complete reinstall?
Never change the system wide links to python to something else. This will break the dpkg package system! See also this post.
Change the python and python3 links back to the system defaults and dpkg/apt-get will start to work again.
$ sudo rm /usr/bin/python
$ sudo ln -s /usr/bin/python2.7 /usr/bin/python
$ sudo rm /usr/bin/python3
$ sudo ln -s /usr/bin/python3.6 /usr/bin/python3
Simon Sudler
  • 4,111
The purpose of miniconda is to install a self-contained version of python. It can be python2 or python3, but this python is managed by miniconda and not apt. What is installed by apt is for the system and as others have said, you should leave them alone.
The one installed by miniconda is not located in /usr/bin/. It depends on where you installed miniconda, but if you installed it without sudo privileges, I guess it should be in ~/.conda/ somewhere.
Alternatively, you can activate miniconda using conda activate or conda activate <environment name>. Then do a which python to find it. If you need to remove these python, you can because they aren't part of the system. (But usually it is required by other packages, so I suggest you leave them alone.) Look at conda remove ....
Ray
  • 2,200
