I've installed resolvconf but for some reason resolvconf-pull-resolved doesn't want to initiate, Any idea what is preventing this, I would think that it's systemd but then again i don't even know what this pull service does
● resolvconf-pull-resolved.service
Loaded: loaded (/lib/systemd/system/resolvconf-pull-resolved.service; static; vendor preset: enabled)
Active: inactive (dead) since Mon 2018-09-24 13:11:46 UTC; 4s ago
Process: 10656 ExecStart=/bin/sh -c cat /run/systemd/resolve/stub-resolv.conf | /sbin/resolvconf -a systemd-resolved (code=exited, status=0/SUCCESS)
Main PID: 10656 (code=exited, status=0/SUCCESS)
Sep 24 13:11:46 Inspire systemd[1]: Starting resolvconf-pull-resolved.service...
Sep 24 13:11:46 Inspire systemd[1]: Started resolvconf-pull-resolved.service.
And journalctl
journalctl | grep resolvconf
Sep 24 12:58:39 Inspire sudo[9844]: root : TTY=pts/0 ; PWD=/etc ; USER=root ; COMMAND=/usr/local/bin/apt install resolvconf
Sep 24 12:58:46 Inspire systemd[1]: Started resolvconf-pull-resolved.path.
Sep 24 12:58:53 Inspire systemd[1]: Starting resolvconf-pull-resolved.service..
I think the service is working fine it's just not expected to continue running. It runs this command:
Reading the man page for resolvconf shows:
The resolvconf package comprises a simple database for run-time nameserver information and a simple framework for notifying applications of changes in that information. Resolvconf thus sets itself up as the intermediary between programs that supply nameserver information and applications that use that information.
Information is added to or removed from the database using the resolvconf program. See the OPTIONS section below for a discussion of the available options.
And the -a option:
-a IFACE.PROG
Add or overwrite the record IFACE.PROG then run the update scripts if updating is enabled. When this option is used the information must be provided to resolvconf on its standard input in the format of the resolv.conf(5) file. Each line in the file must be terminated by a newline.
It appears it creates the resolvconf database and then exits.
In ordered to solve this problem you need to follow this steps.
systemctl start resolvconf.service
systemctl enable resolvconf.service
systemctl start resolvconf-pull-resolved.service
systemctl enable resolvconf-pull-resolved.service
dpkg-reconfigure resolvconf
enjoy!
Pilot6
  • 92,041
sum1n
