-1
Original error:
root@vishal-HP-Notebook:/home/vishal# sudo apt-get install gcc Reading package lists... Done Building dependency tree
Reading state information... Done gcc is already the newest version (4:7.3.0-3ubuntu2). 0 upgraded, 0 newly installed, 0 to remove and 179 not upgraded. root@vishal-HP-Notebook:/home/vishal# gcc gcc: fatal error: no input files compilation terminated.
Following Niclas Börlin's answer:
vishal@vishal-HP-Notebook:~$ cat v.c
#include<stdio.h>
void main()
printf("Mudit");
vishal@vishal-HP-Notebook:~$ gcc v.c
vishal@vishal-HP-Notebook:~$ a.out
a.out: command not found
vishal@vishal-HP-Notebook:~$ gcc --version
gcc (Ubuntu 4.8.5-4ubuntu8) 4.8.5
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
HOW DO I USE IT FOR CODE BLOCKS IDE I've got a method to run on terminal
#include<stdio.h>
void main()
printf("Mudit");
vishal@vishal-HP-Notebook:~$ ./a.out
Muditvishal@vishal-HP-Notebook:~$
I get the same output when I call gcc without any file names, so it looks like gcc is working.
Try gcc file.c on a file with some c code. If the code is correct, it should produce an executable file called a.out.
It is indeed installed
Try the command below and see your current version
> gcc --version
Next go find a tutorial on GCC or read the manual
D-unit
  • 319
  • 15
