I want to delete var/log files due to low disk space, but I cannot find out how.
Hass
As mentioned, you can delete a specific log file with sudo rm /var/log/<FILENAME> or all of them with sudo rm /var/log/*.
I also found this: du -h /var/log/ 2>/dev/null > ~/fileinfo to list the size and path of every log file. To view the result you can use cat ~/fileinfo
Jeremi G
  • 121
1. Open up the terminal
2a. If you are not sure that you want to delete all of the files you can do it one by one
sudo rm /var/log/logfile.log
2b. or all of them at once
sudo rm /var/log/*
abu_bua
  • 11,313
m_krsic
  • 559
