I run Ubuntu in VirtualBox. 18.04 is considerably less responsive than 16.04, with exactly the same VM settings (3D acceleration, 3 cores, 4 GB RAM, guest additions installed, host: macOS, VirtualBox 5.2.18).
18.04 is often slow to respond to clicks and even typing. It is borderline unusable. 16.04, on the other hand, works perfectly fine. The 18.04 is a fresh install.
Is this considerable performance drop an inevitable consequence of switching to Gnome 3? Are there any simple settings I can try to make it usable? I do not need animations or fancy visual effects—this in an OS in a VM so it gets only occasional use, and I mostly just need the terminal.
More details:
  • Right after boot, performance is satisfactory
  • After opening a Terminal, and maximizing it, performance becomes awful. It does not recover even after unmaximizing the Terminal window, or closing it.
  • Turning off 3D acceleration in VirtualBox makes is more sluggish after startup (e.g. moving window on the screen is choppy), but it never gets unusably slow after maximizing a window.
Szabolcs
  • 556
You can install different desktop environments on Ubuntu. Xfce or Mate are pretty fast. Or even better install fresh Ubuntu Mate or Xubuntu 18.04.
tehkonst
  • 363
You could install the virtual box guest additions, that optimizes the virtual machine because I have one installed with 512MB RAM and it runs quite well with it.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
ruben
Check your boot logs:
sudo journalctl --boot > boot.log
Sometimes there is stuff that broke (but does not prevent normal booting) which can add to delays. You will be looking for lines that contain "error", "warning" etc
abu_bua
  • 11,313
prusswan
  • 1,049
