I have Kubuntu 18.04.01 installed on my PC. I'm a computer tech, but I have extremely limited knowledge of Linux. Everything is running fine, but I can no longer update the system.
sudo command doesn't work in the terminal and the Software Center fails to update. I am entering the correct password, but the system fails to update. The Software Center does successfully find the package to update. I get an error message from the Software Center, but it is a light grey background with dark grey text. I'm unable to read it before it shuts off.
Below is the text from the terminal after the root login fails.
sudo apt-get update
[sudo] password for glen:
Hit:1 repo.steampowered.com/steam precise InRelease
Hit:2 us.archive.ubuntu.com/ubuntu bionic InRelease
Get:3 security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB]
Get:4 downloads.plex.tv/repo/deb public InRelease [3,408 B]
Ign:5 dl.google.com/linux/chrome/deb stable InRelease
Hit:6 us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:7 us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:8 dl.google.com/linux/chrome/deb stable Release
Err:4 downloads.plex.tv/repo/deb public InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 97203C7B3ADCA79D
Reading package lists... Done
W: GPG error: downloads.plex.tv/repo/deb public InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 97203C7B3ADCA79D
E: The repository 'downloads.plex.tv/repo/deb public InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Zanna
  • 72,312
There is no problem with your password, all works. You have problem with the plex.tv repository.
Try removing that PPA, for example by unchecking it in Software Sources in Software and Updates. You can try adding it again if you need it.
Zanna
  • 72,312
marosg
  • 1,323
