I can ssh to the server, but sshfs fails with the
read: Connection reset by peer
error. I have checked all the cases pointed out in this AskUbuntu question, the user is in the fuse group, allow_other is correct, the permissions of /etc/fuse.conf are correct.
I use allow_other and idmap options, but I cannot do sshfs while the server allows me to do ssh, but not sshfs and the debug mode says
no matching cipher found: client arcfour server aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com
The server is a Netgear NAS and the user is in the admin group, sftp is also enabled and works.
ssh -vvv results:
OpenSSH_5.3p1, OpenSSL 1.0.1e-fips 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to XXX [XXXXX] port 22.
debug1: Connection established.
debug1: identity file /home/centos/.ssh/identity type -1
debug1: identity file /home/centos/.ssh/identity-cert type -1
debug3: Not a RSA1 key file /home/centos/.ssh/id_rsa.
debug2: key_type_from_name: unknown key type '-----BEGIN'
debug3: key_read: missing keytype
debug3: key_read: missing whitespace
debug2: key_type_from_name: unknown key type '-----END'
debug1: identity file /home/centos/.ssh/id_rsa type 1
debug1: identity file /home/centos/.ssh/id_rsa-cert type -1
debug1: identity file /home/centos/.ssh/id_dsa type -1
debug1: identity file /home/centos/.ssh/id_dsa-cert type -1
debug1: identity file /home/centos/.ssh/id_ecdsa type -1
debug1: identity file /home/centos/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1-hpn14v5 Debian-5+deb8u4.netgear1
debug1: match: OpenSSH_6.7p1-hpn14v5 Debian-5+deb8u4.netgear1 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.3
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug3: Wrote 864 bytes for a total of 885
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-sha1,umac-64@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com
debug2: kex_parse_kexinit: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: mac_setup: found hmac-sha1
debug1: kex: server->client aes128-ctr hmac-sha1 none
debug1: kex: client->server aes128-ctr hmac-sha1 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<2048<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug3: Wrote 24 bytes for a total of 909
debug2: dh_gen_key: priv key bits set: 167/320
debug2: bits set: 1037/2048
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: Wrote 272 bytes for a total of 1181
debug3: check_host_in_hostfile: host XXXX filename /home/centos/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 10
debug1: Host 'XXXX' is known and matches the RSA host key.
debug1: Found key in /home/centos/.ssh/known_hosts:10
debug2: bits set: 1035/2048
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: Wrote 16 bytes for a total of 1197
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug3: Wrote 52 bytes for a total of 1249
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/centos/.ssh/identity ((nil))
debug2: key: /home/centos/.ssh/id_rsa (0x55f3a8a24720)
debug2: key: /home/centos/.ssh/id_dsa ((nil))
debug2: key: /home/centos/.ssh/id_ecdsa ((nil))
debug3: Wrote 68 bytes for a total of 1317
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/centos/.ssh/identity
debug3: no such identity: /home/centos/.ssh/identity
debug1: Offering public key: /home/centos/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug3: Wrote 372 bytes for a total of 1689
debug1: Server accepts key: pkalg ssh-rsa blen 277
debug2: input_userauth_pk_ok: SHA1 fp 82:ba:91:d5:41:f0:ad:cf:40:9b:be:e1:3c:26:c6:f9:98:b8:cf:86
debug3: sign_and_send_pubkey: RSA 82:ba:91:d5:41:f0:ad:cf:40:9b:be:e1:3c:26:c6:f9:98:b8:cf:86
debug1: read PEM private key done: type RSA
debug3: Wrote 644 bytes for a total of 2333
debug1: Authentication succeeded (publickey).
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug3: Wrote 136 bytes for a total of 2469
debug3: Wrote 936 bytes for a total of 3405
debug2: dh_gen_key: priv key bits set: 155/320
debug2: bits set: 949/2048
debug3: Wrote 292 bytes for a total of 3697
debug2: bits set: 1029/2048
debug1: set_newkeys: rekeying
debug3: Wrote 36 bytes for a total of 3733
debug2: callback start
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug1: Sending environment.
debug3: Ignored env HOSTNAME
debug3: Ignored env TERM
debug3: Ignored env SHELL
debug3: Ignored env HISTSIZE
debug3: Ignored env SSH_CLIENT
debug3: Ignored env SSH_TTY
debug3: Ignored env USER
debug3: Ignored env LS_COLORS
debug3: Ignored env MAIL
debug3: Ignored env PATH
debug3: Ignored env PWD
debug1: Sending env LANG = en_US.UTF-8
debug2: channel 0: request env confirm 0
debug3: Ignored env HISTCONTROL
debug3: Ignored env SHLVL
debug3: Ignored env HOME
debug3: Ignored env LOGNAME
debug3: Ignored env CVS_RSH
debug3: Ignored env SSH_CONNECTION
debug3: Ignored env LESSOPEN
debug3: Ignored env G_BROKEN_FILENAMES
debug3: Ignored env _
debug2: channel 0: request shell confirm 1
debug2: fd 3 setting TCP_NODELAY
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug3: Wrote 460 bytes for a total of 4193
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 87380
debug2: shell request accepted on channel 0
Welcome to ReadyNASOS 6.9.3
