When I execute
sudo apt-get update
I get the following error:
E: Type 'ain' is not known on line 3 in source list /etc/apt/sources.list.d/diesch-testing-precise.list
E: The list of sources could not be read.
How can I fix this?
zx485
  • 2,865
The error message is telling you that there is a problem with one of your configuration files. It is kind enough to provide the file in the error. If you do not look at the file, and if you do not show us what line three in the file says, there isn't much anybody can do.
You could use an editor such as nano or vim to look at the file, or you could have the terminal spit out the file contents using cat:
cat /etc/apt/sources.list.d/diesch-testing-precise.list
You may notice the issue and be able to fix it, but please edit your question to include the file entirely, or at least the third line. Have you recently upgraded your system? It may be easier to remove that repository, and re-add it now that you're on a new version.
sudo add-apt-repository -r ppa:diesch/testing # Remove repo
sudo add-apt-repository ppa:diesch/testing # Add repo
Another option is to stick with official Ubuntu repositories, and to limit the number of third party repositories that you use. This will result in a more stable, standard system that others are familiar with to help you, and is the ideal setup for new and old users alike. (No offense to all the hard work put in by Diesch and others.)
earthmeLon
  • 11,658
