I'm running lubuntu 18.04 64-bit on a Trekstor Surfbook a13b. It is dual-booted with Windows 10, where, hardware-wise, everything works perfectly.
The Problem: Lubuntu can't find any wi-fi adaptors, at all – at least with what I've tried. The same problem persists with various other live-distributions (lubuntu 16.04, ubuntu 18.04, ubuntu mate 18.04 – i can imagine that there's not going to be big differences between those, but still)
Windows says the wi-fi unit is an "Intel Dual Band Wireless-AC 3165", which is supposed to work out of the box in linux (or is at least not supposed to be a huge pain to get to work).
I've tried disabling Secure Boot, and this (including getting newer firmware from here).
To have internet access for troubleshooting, I also plugged in a "devolo wifi stick ac", which works like a charm in Windows, but, same as the internal Intel device, doesn't show up at all in lubuntu 18.04.
As of now, I don't have any means at all to connect to the internet under lubuntu.
Could it be a "general PCI/USB bus error", as mentioned here (top answer, under "Identifying the exact hardware")?
Thanks in advance for any help at all!
Some outputs:
uname -r
4.15.0-20-generic
lspci
00:00.0 Host bridge: Intel Corporation Device 31f0 (rev 03)
00:00.1 Signal processing controller: Intel Corporation Device 318c (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Device 3184 (rev 03)
00:0e.0 Audio device: Intel Corporation Device 3198 (rev 03)
00:0f.0 Communication controller: Intel Corporation Device 319a (rev 03)
00:12.0 SATA controller: Intel Corporation Device 31e3 (rev 03)
00:13.0 PCI bridge: Intel Corporation Device 31d8 (rev f3)
00:15.0 USB controller: Intel Corporation Device 31a8 (rev 03)
00:16.0 Signal processing controller: Intel Corporation Device 31ac (rev 03)
00:16.1 Signal processing controller: Intel Corporation Device 31ae (rev 03)
00:16.2 Signal processing controller: Intel Corporation Device 31b0 (rev 03)
00:16.3 Signal processing controller: Intel Corporation Device 31b2 (rev 03)
00:17.0 Signal processing controller: Intel Corporation Device 31b4 (rev 03)
00:17.1 Signal processing controller: Intel Corporation Device 31b6 (rev 03)
00:17.2 Signal processing controller: Intel Corporation Device 31b8 (rev 03)
00:17.3 Signal processing controller: Intel Corporation Device 31ba (rev 03)
00:18.0 Signal processing controller: Intel Corporation Device 31bc (rev 03)
00:18.1 Signal processing controller: Intel Corporation Device 31be (rev 03)
00:18.2 Signal processing controller: Intel Corporation Device 31c0 (rev 03)
00:18.3 Signal processing controller: Intel Corporation Device 31ee (rev 03)
00:19.0 Signal processing controller: Intel Corporation Device 31c2 (rev 03)
00:19.1 Signal processing controller: Intel Corporation Device 31c4 (rev 03)
00:19.2 Signal processing controller: Intel Corporation Device 31c6 (rev 03)
00:1c.0 SD Host controller: Intel Corporation Device 31cc (rev 03)
00:1e.0 SD Host controller: Intel Corporation Device 31d0 (rev 03)
00:1f.0 ISA bridge: Intel Corporation Device 31e8 (rev 03)
00:1f.1 SMBus: Intel Corporation Device 31d4 (rev 03)
iwconfig
lo        no wireless extensions.
sudo lshw-C network: no output
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo rfkill unblock all: no output
dmesg | grep -i firmware
[    0.039204] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    2.644892] i915 0000:00:02.0: Direct firmware load for i915/glk_dmc_ver1_04.bin failed with error -2
[    2.644895] i915 0000:00:02.0: Failed to load DMC firmware i915/glk_dmc_ver1_04.bin. Disabling runtime power management.
[    2.644897] i915 0000:00:02.0: DMC firmware homepage: https://01.org/linuxgraphics/downloads/firmware
dmesg | grep -i -e 0280 -e sdio
[    0.028000] tsc: Fast TSC calibration using PIT
There are four Hardware-IDs found through the Windows 10 Device Manager:
PCI\VEN_8086&DEV_3165&SUBSYS_80108086&REV_81
PCI\VEN_8086&DEV_3165&CC_02800
