I am new to Linux and have recently installed Ubuntu 18.04. I need to edit the 50-synaptics.conf file in Ubuntu 18.04, but GKSU is deprecated, and when I run
gedit admin:///usr/share/X11/xorg.conf.d/50-synaptics.conf
it shows:
The specified location is not mounted.
What should I do to open and update this file?
output
aayush@aayush-taneja:~$ gksu gedit /usr/share/X11/xorg.conf.d/50-synaptics.conf
Command 'gksu' not found, did you mean:
command 'ksu' from deb heimdal-clients
command 'ksu' from deb krb5-user
command 'gosu' from deb gosu
Try: sudo apt install <deb name>
aayush@aayush-taneja:~$ sudo apt install gksu
[sudo] password for aayush:
Reading package lists... Done
Building dependency tree
Package gksu is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'gksu' has no installation candidate
aayush@aayush-taneja:~$ gedit admin:///usr/share/X11/xorg.conf.d/50-synaptics.conf
** (gedit:4614): WARNING **: 22:17:30.045: The specified location is not mounted
^C
