I've been trying to connect to the internet via my adapter all day, the only way I'm able to post this is via USB tethering.
Earlier, I noticed I wasn't able to connect to the internet on this computer. I thought I'd just redo what I did when I first set up this computer which worked really well: Netgear A7000 on Ubuntu 16.04 not working - though I tried that twice and it didn't work, so I'm stuck on here looking for outdated answers from questions from 2015.
I used lsusb, and this is what shows up: https://pastebin.com/JuyCqaNB
Any help is appreciated, thank you.
First, we need to remove the dkms installation:
sudo dkms remove rtl8814au/4.3.21 --all
Confirm that it is no longer present:
sudo dkms status
You should see no 8814au entries. If so, proceed.
Next, find where you cloned the driver files:
sudo updatedb
locate rtl8814au
You want the one in your /home/[user] directory; /home/ubuntuisscary for example. Change to that directory using the bash shorthand for '/home/ubuntuisscary', or whatever your user directory is named:
cd ~/rtl8814au
If you find that the file is in Downloads, then:
cd ~/Downloads/rtl8814au
Now we build the file for your current kernel.
make clean
git pull
make
sudo make install
sudo modprobe 8814au
Any improvement?
EDIT: When Update Manager installs a newer kernel version, also known as linux-image, after the requested reboot, recompile:
cd ~/rtl8814au
make clean
git pull
make
sudo make install
chili555
  • 61,330
