I installed Ubuntu 18.04.1 on my new HP laptop. The trackpad/touchpad does not work; it is not detected at all.
Both xinput -list and less /proc/bus/input/devices do not show any touchpad device.
dmesg | grep -i pad
also gives no output regarding to the trackpad.
I am aware that the laptop is very new, so I updated the kernel to 4.18.7 as well as 4.19.rc3 (the latest), but with no luck, nothing is detected.
Sorry for my dumb questions, but what should I do in this case? Is this a kernel problem or an Ubuntu distribution problem? Where can I obtain support?
this solution does not work: Touchpad is not recognized
UPDATE:
As of linux kernel 4.19 stable, the trackpad is fully functional. Ubuntu user needs to manually upgrade the kernel to get it work, or wait until next point release :) cheers
Booo
  • 131
I have similar problem. I test it on ubuntu 16,18 with same result. While I can see the device and set its value to "enable" xinput set-prop 11 "Device Enabled" 1 it is not working. In addition, when I installed xserver-xorg-input-synaptics or xserver-xorg-input-all I have lost keyboard as well and had to re-install. Please let me know when the driver is available.
update: adding boot option acpi=off works for me but it`s not a solution because the system than can't turn off.
pefi
I had the same problem. I was not able to get the touchpad to work using 16.04, but I have gotten it to work with 18.04. I do not remember exactly how I did, however.
First, when you type: less /proc/bus/input/devices in the terminal, can you identify a touchpad device?
If that is the case, then you can execute the following:
sudo apt-get purge synaptics-touchpad
sudo apt-get install --reinstall xserver-xorg-input-synaptics
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
In the HP zbook 15 G5 with ubuntu 18.04 touchpad worked in an erratic manner - sometimes it could work even a day without any reason and then stop abruptly. It was still listed in /proc/bus/input/devices. Upgrading the kernel to 4.19 solved the problem. The new kernel will be included in ubuntu 19.04 (to be released on 18th April 2019).
whamalai
  • 171
On my zbook 15 G5, after the software update, the touchpad started working, else execute the following command:
sudo apt-get install gnome-control-center
For hanging issue, its a nvidia graphics card issue, so run the following command: sudo apt-get install nvidia-384
Anil
