I am trying to use one of the shell commands to a python script, but struggling with some syntax error here.
The description of the command is from here
echo /dev/bus/usb/`udevadm info --name=/dev/ttyUSB0 --attribute-walk | sed -n 's/\s*ATTRS{\(\(devnum\)\|\(busnum\)\)}==\"\([^\"]\+\)\"/\4/p' | head -n 2 | awk '{$1 = sprintf("%03d", $1); print}'` | tr " " "/"
This command works well on the terminal, but trying to import this a python script
import subprocess
cmd = "/dev/bus/usb/`udevadm info --name=/dev/ttyUSB0 --attribute-walk | sed -n 's/\s*ATTRS{\(\(devnum\)\|\(busnum\)\)}==\"\([^\"]\+\)\"/\4/p' | head -n 2 | awk '{$1 = sprintf("%03d", $1); print}'` | tr " " "/""
p = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
out, err = p.communicate()
print out
print err
Get a syntax error on a sprintf statement, which doesn't explain much or doesn't like modulo (%)
Vikram
  • You can't use " within "'s. Your command split into parts
    cmd = "
    | head -n 2
    | tr " " "/"
The " on line 1 and line 7 interfere with the " on lines 5 and 6. You need to escape those. Line 3 escapes them correctly.
See the string literals section.
  • Untested, but you probably need to do it like this:
    cmd = "
    | head -n 2
    | awk '{$1 = sprintf(\"%03d\", $1); print}'`
    | tr \" \" \"/\"
Maybe this works too:
cmd = "/dev/bus/usb/`udevadm info --name=/dev/ttyUSB0 --attribute-walk | sed -n 's/\s*ATTRS{\(\(devnum\)\|\(busnum\)\)}==\"\([^\"]\+\)\"/\4/p' | head -n 2 | awk '{$1 = sprintf('%03d', $1); print}'` | tr ' ' '/'"
I changed " into '.
Rinzwind
  • 309,379
