I dual boot Windows 10 and Ubuntu 18.04. Space on my SSD was getting a little cramped so I wanted to delete my large swap partition and use a swapfile instead like in the default installation. I correctly created a swap file and edited the appropriate line in fstab and rebooted and free showed it was using the file. I booted into a live usb of ubuntu and ran gparted to delete the swap partition and extended ubuntu to free space and it went well.
When I tried to boot grub2 kept going to rescue mode. I tried to boot to windows but it gave me an error. I rebooted into the live usb to run boot repair and couldn't get it to fix grub so I switched over to repair MBR and I was able to boot into Windows again but gives me no option to boot ubuntu.
Now I try reinstalling grub with boot repair and it keeps giving me errors. I have pastebin here and it says something about not finding EFI partition. sudo fdisk -l gives this:
Disk /dev/loop0: 1.8 GiB, 1864450048 bytes, 3641504 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 86.9 MiB, 91099136 bytes, 177928 sectors
Disk /dev/loop2: 34.7 MiB, 36323328 bytes, 70944 sectors
Disk /dev/loop3: 140.9 MiB, 147722240 bytes, 288520 sectors
Disk /dev/loop4: 2.3 MiB, 2433024 bytes, 4752 sectors
Disk /dev/loop5: 13 MiB, 13619200 bytes, 26600 sectors
Disk /dev/loop6: 14.5 MiB, 15196160 bytes, 29680 sectors
Disk /dev/loop7: 3.7 MiB, 3887104 bytes, 7592 sectors
Disk /dev/nvme0n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
Disklabel type: dos
Disk identifier: 0x0001a5ef
Device Boot Start End Sectors Size Id Type
/dev/nvme0n1p1 * 2048 914407423 914405376 436G 7 HPFS/NTFS/exFAT
/dev/nvme0n1p2 914407424 915329023 921600 450M 27 Hidden NTFS WinRE
/dev/nvme0n1p3 915331070 1000214527 84883458 40.5G 5 Extended
/dev/nvme0n1p5 915331072 1000214527 84883456 40.5G 83 Linux
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x6f63051a
/dev/sda1 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 1953110015 1952903168 931.2G 7 HPFS/NTFS/exFAT
/dev/sda3 * 1953110016 1953519615 409600 200M 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0x0000ddff
/dev/sdb1 * 2048 976769023 976766976 465.8G 7 HPFS/NTFS/exFAT
Disk /dev/sdc: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Disklabel type: dos
Disk identifier: 0xb95cbb7b
/dev/sdc1 2048 488394751 488392704 232.9G 7 HPFS/NTFS/exFAT
Disk /dev/sdd: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Disklabel type: dos
Disk identifier: 0x663eb4c4
/dev/sdd1 * 0 3815135 3815136 1.8G 0 Empty
/dev/sdd2 3737268 3741939 4672 2.3M ef EFI (FAT-12/16/32)
I know I have a lot of physical drives with old installations but the one I want is on /dev/nvme0n1 which is my main boot drive. I have my ubuntu with a custom set up for my development environment so I really don't want to reinstall ubuntu if it's just boot errors. How do I setup grub2 to be the default boot manager.
EDIT: I tried creating an EFI partition following this guide and I created the partition but I can't install grub. sudo update grub outputs /usr/sbin/grub-probe: error: failed to get canonical path of ``/cow'. (only one backtick near cow) As requestedsudo parted -l gives this
Model: ATA WDC WD10EARX-00N (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary ntfs
2 106MB 1000GB 1000GB primary ntfs
3 1000GB 1000GB 210MB primary ntfs boot
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sdb: 500GB
Sector size (logical/physical): 512B/512B
Disk Flags:
1 1049kB 500GB 500GB primary ntfs boot
Disk /dev/sdc: 250GB
Disk Flags:
1 1049kB 250GB 250GB primary ntfs
Warning: The driver descriptor says the physical block size is 2048 bytes, but
Linux says it is 512 bytes.
Ignore/Cancel?
Ignore/Cancel? ignore
Model: Generic- SD/MMC (scsi)
Disk /dev/sdd: 128GB
Sector size (logical/physical): 2048B/512B
Partition Table: mac
Disk Flags:
Number Start End Size File system Name Flags
1 2048B 6143B 4096B Apple
2 1913MB 1916MB 2392kB EFI
Model: NVMe Device (nvme)
Disk /dev/nvme0n1: 512GB
Partition Table: gpt
Disk Flags:
3 1049kB 211MB 210MB fat32 EFI System boot, esp
1 211MB 468GB 468GB ntfs Microsoft basic data msftdata
2 468GB 469GB 472MB ntfs Windows RE diag
5 469GB 512GB 43.5GB ext4 Linux filesystem
Edit 2: So I was able to boot my ubuntu installation into efi mode and was able to install grub-efi. I was able to enable secure boot and disable CSM and ubuntu still loaded. Only issue is Windows won't boot now though I assume because it still thinks its in MBR mode. Im making a live windows usb to fix the issue though I don't know if it'll mess up the EFI partition I setup. Is that the correct way to fix it?
