I would like to compile opus-tools with libopus 1.2.1.
I got libopus 1.2.1 source code from here : https://opus-codec.org/release/stable/2017/06/26/libopus-1_2_1.html
I extracted it, and then did :
./configure
make
sudo make install
Everything went fine and now I have an "opus" folder in /usr/include and some "libopus.*" files in /usr/local/lib
Now I got opus-tools source code from here : https://opus-codec.org/downloads/
I extracted it, and then did : ./configure And I got this error message at the end :
checking for Opus... no
*** Could not run Opus test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means Opus was incorrectly installed
*** or that you have moved Opus since it was installed.
configure: error:
    Opus is required to build this package!
    please see http://opus-codec.org/ for how to
    obtain a copy.
How come it doesn't find the libopus library I just built ? How can I link to it ?
Thank you for your help ! Cheers
Ofboir
Installing packages from repositories
OPUS is packaged in Ubuntu (including 18.04 LTS). All you need is to search on packages.ubuntu.com for opus.
And you will get the following packages:
  • Package libopus-dev
    bionic (18.04LTS) (libdevel): Opus codec library development files
    1.1.2-1ubuntu1: amd64
  • Package libopus0
    bionic (18.04LTS) (libs): Opus codec runtime library
    1.1.2-1ubuntu1: amd64 ...
  • Package opus-tools
    bionic (18.04LTS) (sound): Opus codec command line tools [universe]
    0.1.10-1: amd64
So I suggest to install these packages from repositories:
sudo add-apt-repository main
sudo add-apt-repository universe
sudo apt-get install libopus-dev libopus0 opus-tools
Manual compilation (bad idea)
Enable Source Code repository in Software & Updates (software-properties-gtk).
Install opus build-dependencies:
sudo apt-get build-dep libopus0 opus-tools
Download and compile new opus (are you sure that 1.2.1 is better than 1.1.2-1ubuntu1?):
cd ~/Downloads
wget https://archive.mozilla.org/pub/opus/opus-1.2.1.tar.gz
tar -xf opus-1.2.1.tar.gz
cd opus-1.2.1/
./configure
make
sudo make install
Download and install opus-tools (exactly the same version as in repository):
cd ~/Downloads
wget https://archive.mozilla.org/pub/opus/opus-tools-0.1.10.tar.gz
tar -xf opus-tools-0.1.10.tar.gz
cd opus-tools-0.1.10/
./configure
make
sudo make install
Note: the sudo make install is bad idea too, consider to use checkinstall instead.
N0rbert
  • 103,263
